Tail Light Modifications
defsix
Just done the Taillight mod on my B8 Avant. I only added 3 to the value of the four different channels. This resulted in outer, middle and inner lights on full with breaking. Indicators are ROW, if I add 6 they would flash with indicators. Looks cleaner now. LED Bulbs next!
Is there a complete list of what each channel does somewhere?
Anyone else tried this?
QUOTE=STA4;10690018]Here's a summary of the coding to enable the middle and inner bulbs as brake/signal for the B8 halogen:
Module 46 - Adaptation
Password: 16017
Sedan (Limo):
Channel 195: Left middle - 10753 -> 10759 (add 6)
Channel 196: Right middle - 10785 -> 10791 (add 6)
Channel 203: Left inner (on Limo also Fog) - 8778 -> 8775 (subtract 3)
Channel 204: Right inner (on Limo also Fog) - 8810 -> 8807 (subtract 3)
Avant:
Channel 195: Left middle - 14849 -> 14855 (add 6)
Channel 196: Right middle - 14881 -> 14887 (add 6)
Channel 203: Left inner (on Limo also Fog) - 14849 -> 14855 (add 6)
Channel 204: Right inner (on Limo also Fog) - 14881 -> 14887 (add 6)
Bulb out warnings:
Channel 181: 65535 -> 0 (rear halogen to LED conversion)
Channel 191: 65295 -> 0 (disable all rear bulb out warnings)
Channel 192: 3 -> 2 (disable licence plate bulb out warning)
[/QUOTE]
V2brett
So as i understand this you can make all rear red lights on a halogen car shine as brake lights just like an led car does? Ie the lights on the tailgate will shine as brake lights too?
defsix
That is correct. The Fog lights are separate, however on saloon I believe you lose the fog light feature. I will upload a picture tomorrow...
defsix
Pictures as promised.
M90KKL
Can anyone make this understandable for someone with less intelligence I like the idea of brighter rear lights. So what do I gotta do?
defsix
Usually when the tail lights are on the 3 bulbs illuminate on either side. When the brake light comes on only the outer one gets brighter. With this mod all 3 get brighter, to standard brake light level, when the brakes are press.
This post http://www.audi-sport.net/xf/threads/karls-3-0-tdi-build-thread.204785/page-10#post-2652134 has a better picture !
defsix
The inner lights work as brake lights at all times with this mod so makes the brake lights a bit more noticeable in the day. Also means you effectively have 3 brake light bulbs each side of the car instead of 1 so if a single bulb fails you still have brake lights both sides.
The outer ones work as the break lights by default, not the inner.
desertstorm
Moderator
Staff member
Moderator
I know thats what I said isn't it. Missed some punctuation though I think :blush: . Should be .
The inner lights work as brake lights at all times with this mod, so makes the brake lights a bit more noticeable in the day
The inference is that the inner lights don't work at all as brake lights normally.
The picture really shows the difference. Again thanks for posting this.
defsix
No worries! It's your picture explains it a lot better than I could.
I'm surprised no else had tried it before... I stumbled on it trying to get the adaptive Brake lights working.
V2brett
Cheers guys ill give this a go at the weekend, i always thought it looked rubbish with just the outers as brake lights.
Well done that man
V2brett
Beware guys iv just done this and had to revert back to normal as the inner lights are flashing with the indicator lights. My cars an 08 with led indicators, its worth double checking all lights work correctly after doing this mod.
V2brett
Exactly what i did mate, my fault for speed reading the Op.
Looks like back to the car with the vcds.
Cheers desertstorm
M90KKL
And I assume once Iv got this I'll need a laptop and software..? All above my head lol anyone Glasgow area that has the kit?
defsix
Here is the chart with the different coding options. Write down your own code before you start.
V2brett
Quick vid for you guys, its a big improvement looks and safety wise and is how the car should be from the factory imo.
th_EEC1CDA3-87CA-4A92-92E4-2B1AA7C4675A_zpsedh9kyno.mp4
viceroy
This is awesome. Means I'll be able to code my aftermarket dectane lights so the brake leds ALL light up instead of only the outer lights.
Rick0330
Hi.
Using this coding is it possible to make my fog lights to come on when I put the car in reverse gear???
Sent from my SM-G930F using Tapatalk
Rick0330
When I say fog lights I mean Rear fog lights.on when in reverse.. to aid In reversing..
jdp1962
Grumpy Old Man
It's my birthday
I can't see a problem . Reverse lights are not part of Mot so should be fine if it's possible
That wasn't my point. Is it legal to show a high intensity red light simply because you're reversing, rather than because weather conditions have reduced visibility to the point where the normal rear lights aren't sufficient?
Rear fog lights - like front fog lights - exist for a specific reason, and the regulations reflect that (no pun intended :) ).
Rick0330
The reverse lights are pants .. more light required that's all .. no street lights where I am .. so don't you worry...
Rick0330
I'm not worried. I'm just asking a sensible question. :)
In theory the fog lights are not at that time if the switch is not pressed and an indication on the dash is showing fogs on.
It's only the same as holding the brake light on... that's what I have to do at the minute to get enough light , if it's not possible then hey ho...
