  2. Dismiss Notice
Facelift Suspension
Ojawed Mar 26, 2020
  1. Ojawed
    Ojawed Member
    33
    Hi guys i have a fl without magride.
    I want to improve the ride...currently it feels a bit too bouncy.
    I dont want the car too low as its a daily.
    What springs do people suggest?
  2. Avatar
    snack-media
    Advertisement
  3. DPM
    DPM Site Sponsor Site Sponsor
    5,392
    329
    What kind of drop were you wanting?
    Damian @ DPM Performance
  4. Ojawed
    Ojawed Member
    33
    As little as possible to be honest..around 10mm front and back
  5. TRANC3
    TRANC3 Member
    47
    24
    Avoid KW H.A.S. - awful in terms of running noises whilst turning.
  6. Slowracer
    Slowracer Active Member
    306
    208
    43
    Eibach pro kit is around 10-15 mm drop. I tried them with Magride and didn't like them, too soft IMO. Stock springs handled better.
  7. DPM
    5,392
    329
  8. Ojawed
    Ojawed Member
    33
  9. Scottkcollins
    Scottkcollins Member
  10. Slowracer
    306
    208
    43
    I have MSS height adjustable springs. Good ride quality but expensive.
    Since you have fixed suspension then coilovers are an option since you don't need to have the mag ride deletes. I've heard good things about the bilstein b14 coil overs, just depends how much you want to spend.
  11. Ojawed
    Ojawed Member
    33
    I was tempted to go for mss.but most reviews say that they perform better on mag ride cars.
    And some people have said they are noisy.
  12. Avatar
    snack-media
    Advertisement
  13. Slowracer
    306
    208
    43
    If installed properly they're not noisy, haven't had a peep out of mine.
    There are other comparable HAS spring options. KW, Eibach (only rear adjusters), ground control. All reputed to have good ride quality. I think ground control can be specced for spring rate and have adjusters on the bottom so easy to adjust on the car.
  14. arf @66
    arf @66 Member
    35
    17
    If the standered springs are too stiff for you,i dont have magride.i fitted the mss track springs and they are noticably softer.just did about a 10mm drop and still clears every speed bump i have gone over.
  15. Oli.
    Oli. Active Member
    618
    56
    KWV3 is what I’m running - I ditched the magride and MSS Springs for it.
    Fantastic upgrade, although pricey
  16. SJGS3
    SJGS3 New Member
    Oli, why did you move away from the Mss set up? I believe you have been running that set up for nearly two years now?
    Oli. likes this.
  17. Slowracer
    306
    208
    43
    Fantastic upgrade, although pricey[/QUOTE]
    What's the ride quality like in comparison to your stock shock set up.
    I've been in a car with the KW DSC, they handled great in the 2nd setting (sports) but ride was a bit jiggly in comfort mode.
  18. DPM
    5,392
    329
    The H&R springs are a good option. Fairly handling orientated so firm but refined.
  19. Oli.
    Oli. Active Member
    618
    56
    The MSS was good and I ran for 18 months with both 20” and 19” wheels but they just never felt perfect. So I ditched the magride, put in a delete and fitted the KWV3. Absolutely transformed the drive in every way. Less understeer, better ride, deals better with road imperfections - I just can’t fault it. So much so I’ve ordered the same for my new T6.1.
    I've been in a car with the KW DSC, they handled great in the 2nd setting (sports) but ride was a bit jiggly in comfort mode.[/QUOTE]
    I’ve ditched the magride. They are so much better- see comments above.
    Slowracer and SJGS3 like this.
  20. craigpanthercrystal
    craigpanthercrystal Active Member
    425
    155
    43
    Eibach Sport all day long!
  21. ARESSTREE
    ARESSTREE New Member
    13
    MSS here, brilliant
