Suspension Options
Jack Kelly Sep 14, 2018
  1. Jack Kelly
    Jack Kelly 265 BHP 2.0 TFSI Saloon
    53
    Hi guys,
    Not posted for a while but looking at suspension options as mine is on the way out.
    I've heard some slightly lowered suspensions can actually ride better and handle better than the stock S Line suspension?
    What is a good set up to go for if you want a 10-40mm drop and try to maintain or improve ride quality?
  2. Avatar
    Google AdSense Advertisement
  3. DPM
    DPM Site Sponsor Site Sponsor
    5,248
    283
    10-40mm drop is quite a range but to get a full 40mm drop on the s-line you'd need coilovers.
    Damian @ DPM Performance
  4. Jack Kelly
    53
    Thanks Damian, I'd rather something like 20 - 30mm, but wanted to give a range so I didn't exclude anything really good. Do you have any recommendations for coilovers? Seen various mentions of AP and Eibach for this model, but not sure if there is a best set up?
  5. Just Rob.
    Just Rob. Moderator Staff Member Moderator Regional Rep Team Brilliant Black Team Daytona TFSI Owners Group VCDS Map User Gold Supporter Audi A4 Audi Avant Owner Group quattro S-line owners group Manual
    8,759
    4,797
    Bilstein B8's withH&R 45mm springs , works really well.
  6. Jack Kelly
    53
    Thanks Rob, how do you find the ride and handling? Much better than stock? How much lower did this make your car?
  7. Just Rob.
    8,759
    4,797
    Excellent setup, can't fault it ,thought about changing it while back then realised what a mistake it would be, very happy with.
  8. Jack Kelly
    53
    Thanks mate, sounds good. Have you got any pictures? I've seen your car around but can't hunt the pictures down!
  9. Just Rob.
    8,759
    4,797
    Here is one from July.
  10. Nathan Russell
    Nathan Russell Active Member Team V6 Team Phantom Audi Avant Owner Group S-line owners group
    246
    I’ve just put St Coilovers in mine mate. Changed the rear springs from the st ones to hyperco 7.5” couldn’t be happier. Im lower than 40mm over standard s line and the ride is incredibly good!!
  11. ANDY2.0
    ANDY2.0 Member
    30
    29
    AP Coilovers. Rides better than stock S-Line. Very happy with it:grinning:
  12. Avatar
  13. boffin486
    boffin486 Well-Known Member TFSI Owners Group TDi Audi A4 Audi Avant Owner Group quattro S-line owners group
    350
    580
    93
    Hi folks - is the general concesus for 45mm lowered springs all round for a TFSi Avant S Line?
    Howabout adjustable upper track control arms for the front to avoid killing your tyres (dial out the negative camber) ? I don't understand why these are NOT available anywhere in the UK & have to come fom the States........
    I want to mod my B7 (already did all this on my B6 using a JOM set of adjustable coilovers & adjustable contol arms) as the front sits far too high with the standard S Line suspension . I may well get another JOM set & get on with it.........
  14. antwan64og
    antwan64og Well-Known Member
    1,033
    271
    Are Bilstein B12 kits recommended on the forum?
    Bilstein B8 shocks with Eibach springs with a 30mm drop.
    Can anyone clarify when suspension say a 30mm drop presumably its from stock height?
    So would 30mm drop be the same as stock S-Line suspension.
  15. DPM
    5,248
    283
    What's your budget?
  16. Jack Kelly
    53
    Around £600
  17. DPM
    5,248
    283
    What's your engine size and FWD or Quattro?
