JamJay
Hi all,
I know this is a query for the Leon Cupra R but you use the same front suspension setup on the S3 as far as I am aware.
I noticed this weekend that the front drivers side is creaking when going over bumps in the road, it sounds like a 'rubber' creak if that makes sense, not metal on metal (but I could be wrong). This happens when I crawl over a speed hump but also with bumps in the road surface at slow speed, say under 15mph. When the car gets up to speed, 20mph+ then the noise is completely gone and for example, a trip onto a rather uneven section of the M25 yesterday caused no noises at all.
The top mounts and bearings are new and so are the front wishbones including all bushes. There are 10mm spacers on the front and the noise didn't seem to increase after fitting, the wheel is also on tightly.
So what do you think it could be?
I hardly use the car so excessive abuse won't be the cause and I've not hit anything hard. I think I heard this noise a little while back, shortly after fitting the coilovers but has since become more audible with the freezing temperatures.
Maybe it's a case of whipping off the wheel, jet washing the components of dirt and regreasing?
Any info much appreciated, I'd like to put this noise to bed on the weekend.
