weekenny
Can I use a pulley removal tool from another car? For example a pulley tool for a Mini Cooper S is much less expensive than any of the S4 pulley tools on the market.
This is the cheapest pulley removal tool I've found, used it to remove my SC pulley no problem just needed to unbolt the charger and lift it up a few inches for clearance but saved removing the whole front of the car.
https://www.ebay.co.uk/p/Silverline-Puller-for-Ribbed-Pulleys-35-165mm-256243/1731068138
Did you need to use the puller in reality of can this pulley just get tapped off once the bolt has been removed?
