Stuck on bleeding brakes
Murf
Just bled them with eezibleed, Pedal is firm with car off. Turn car on and pedal goes to the floor. Any ideas? Thanks in advance.
Badger 5 Edition...Its all about the flow...
Staff member
Moderator
Bled the master cylinder? pedal will be hard with the engine off as the vacuum will disipate as you pump the pedal with the engine off... this is by design
s33nyboy12
Also tuffty as you pointed out to me , 2 nipples on b.m.c are very stiff and snap easily, use ptfe lube or wd40 , lots of it!
