strange rapid clicking from instrument cluster when turning ignition on and off
cypher007 Sep 13, 2018
  1. cypher007
    cypher007 Member
    81
    I get a rapid clicking sound like a relay behind the instrument cluster for about 10s then stops. this happens every time I turn the ignition on or off.
  2. Avatar
    Google AdSense Advertisement
  3. samuelh_888
    samuelh_888 Well-Known Member Audi S3 Black Edition Manual
    1,630
    662
    Have you scanned and if so was it VCDS? If not, try to find someone with VCDS and scan it.
  4. cypher007
    cypher007 Member
    81
    scanned it has the 01435 code and a anti shudder error.
  5. samuelh_888
    1,630
    662
  6. cypher007
    cypher007 Member
    81
    Found out it is most likely when they took apart the instrument cluster to stuff insulation tape in the esp mil and steering wheel led holes, *******, they damaged the speedo actuator. I’m trying to fix it. Got rid of the chatter on startup and shutdown but after a test drive the needle is stuck. So will have to strip it down again tomorrow.
    So it looks like who ever sold the car to the owner I bought it from did some monkey business with the fault lights.
  7. ch1z64
    ch1z64 C'mon you's bhoy's in Green Team Imola TFSI Owners Group Silver Supporter Team Sprint Audi S3 Manual
    3,590
    766
    Unless you really know what your doing and kinda think you will fix it for good you might want to take it to one off these retrofitters @Ash187 or @NHN
  8. samisnake
    samisnake Active Member
    481
    204
    43
    Do you get commission
  9. ch1z64
    3,590
    766
    NOPE , just a believer if i can't help the person why not put them onto some who can , i live by the code fix it once and right and these guys do , which many other members think the same or they wouldn't have as many people singing there praises.
