s3 addict
Hi, I have a 2001 AMK S3 and I'm having a job finding this boost issue. Basically the car will boost if I feather the throttle a bit first, You can here the change in pitch from the turbo. But if i put my foot down straight away it wont boost until i'm above 4-5k revs. This seems more of an issue in 1st and 2nd gear. I've replaced the N75 valve and this made no difference, I've disconnected the MAF and it made no difference. I do have a leak on my crankcase breather pipe but I'm not sure how that would effect it? I've plugged in my vag reader and no codes were found. The only other issue I have is the lateral acceleration sensor is intermittently failing but that cant have any effect on the turbo surely? Could this be an issue with the waste gate actuator? The boost hoses seem fine. Any help would be very much appreciated.
