Following on from the coolant dumping episode the other week,I have driven my S3 a couple of times and the first time it seemed a bit sluggish on acceleration and then the second time on hard acceleration it was 'missing' and 'holding back' which then caused the EML to light up
may just be a coincidence but mo matter it seems the car just wants to put a dampener on the festive season for me.
I did a 'Lite' scan and got the code...
17963/P1555 - Boost Pressure Control: Upper Limit Exceeded
Possible Symptoms
- Reduced power output
- Limp mode
Possible Causes
- Boost Pressure too High
- Hoses/Pipes incorrect connected, disconnected, blocked or leaking
- Charger Pressure Control defective
- VNT (variable nozzle turbo): nozzles stuck
- Solenoid Valve for Boost Pressure Control (N75) defective
Had a quick look around that area and found this...
Where the DV pipe meets the branch of the TIP a couple of peek-a-boo holes!
For now I have just stuck a bit of superglue and gaffer tape on it just to get me through to new year and then I'll sort it.
I understand it's not the correct way to botch it for now,especially as I know
@Stuart B would scorn at me for not using araldite
and the problem still exists afterwards anyway!...Obviously need to now enter the myriad of which silicone TIP to get.I'm sure Santa will know as it seems it will be less 'smellies and socks' and more S3 parts under the tree this year.
Could of done without this right now as I have been hunting down my oil leaks recently and yes,you've guessed it already,the damn half moon gasket is leaking so that's another job for January.There is also oil weeping out of where the cam chain tensioner solenoid sits.Apparently there is an 'o' ring inside but it can't be bought separately so need to think how to get round that one or hopefully someone will be able to educate me,again
Hope you're having better luck,wherever you are.
So to anyone who reads this thread or happened to stumble across it by accident,I wish you all a Merry Christmas and a luckier New Year
This Christmas period I expect to be drinking more than I should and trying to stay away from my S3 as much as possible..
