Oh5ttQuattro
After wasting probably over a thousand dollars chasing a problem it turned out to be the diaphragm in the wastegate actuator. I fitted a new actuator last night and adjusted it to the same exact length as the original and the car feels worse than before. I'm going to try and loosen the preload but i'd like to know exactly how to do this.
https://www.ebay.com/itm/Turbocharger-Turbo-Actuator-Wastegate-Audi-A3-S3-TT-Seat-Leon-1-8-Cupra-R-K04-23/391719605576?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
I was getting a 17705 and after a week or sometimes randomly i'd get a lean code. Now after this the 17705 still came back. I'm guessing it's because the computer is seeing a difference in commanded boost vs actual boost? Can someone show me how to interpret the logs. I'd like to know how to adjust this and how I could've found the issue before wasting a lot of time, money and sanity.
I cut the old wastegate actuator apart and the diaphragm was definitely leaking there was also mineral oil on the other side of the diaphragm from the smoke tester. The leak was so small and only leaked above more pressure than the smoke machine could make it was impossible to find. It would hold 5 psi for a couple minutes or more. I even tried pumping in smoke then pressurizing the line, but in the end I just bought a hand pump that could produce more pressure.
