boost-addict
right.... so when i got the car the abs light was on and there was 3 beeps on the clocks (researched that to be a dead abs module)
so its been like that some time, i got a s/h one thats been tested working. ive plugged it in and still no response from the abs controller.
so what now? do i need a registered version of vagcom to work round it and find the fault? or does it need coding? altho as theres no response im not sure. any chance of there being a broken wire anywhere?
with the old abs module when plugged in it locks you out of every thing, but this time it hasnt.
ive got the same part numbers as the old one.
one thing that is becoming apparent is the seller of the car also supplied a set of clocks. and when looking in to it it also showed no response from the instruments,, altho with the dead abs module unplugged, i then could access as much as vagcom lite would let me,
sooo.... what do i do now?
