Steering wheel angle sensor Fault
Kevin mathews
Dubai
So i had just done the swap for msfw steering and now there is a fault for the steering angle sensor showing up now
Dunno how to solve the problem
Someone please help
Also i have added the screenshots of the faults showing
Sent from my SM-N970F using Tapatalk
If you just changed the wheel only & no other modules, take it for a drive, they'll clear.
Only the steering and the ecu .
Took it for a drive still not clearing dont know why
If you changed the module too, then you have to recalibrate the steering angle sensor, of course the module must match the slip ring version, research the forum has all this info to resolve.
ross tech as a guide with vcds to re-calibrate it
Any link for compatible sliprings so i can check?
My current slip ring is 1k0959653D
And my new steering ecu 8P0953549F
Can someone help if my steering sensor and ecu are compatible
You can reset the steering angle manually by turning the steering wheel fully to the left....hold for a good few seconds....all the way to the right.....again hold for a good few seconds.......and then return to centre...it should go off then after driving a few metres.
That's as long as the ecu is coded correctly
Reactions: Kevin mathews
Will give that a go
Search your vcds error codes on rosstech. They have full instructions on everything
