I've been having issues with starting the engine (BRD 170 TDI) over the last few months, I had thought it was the battery at 1st and swapped that and all was well for a few weeks but the problem returned.
Sometimes it takes about 3 - 6 attempts to turn over after turning the key, Other times it will crank once then pause for a few seconds as if its died... then springs to life.
I was then thinking that the glow plugs may be bad but in the cold frosty morning we had a few days ago the engine started great !
After some misinformation I recently changed my Fuel Temp sensor which made no difference, but after a little research I found the plug for the Coolant Temp Sensor (PITA to get to) I tried starting with this unplugged and the engine fires lovely !
Is this a sign that the CTS is duff and my problems will be cured by replacing this ? or do you think there is an underlying problem ?
also, is it OK to run with the CTS disconnected until a replacement arrives or will that be bad for the engine ? (although, it already has the now infamous rough idle when warming up/idleing along with white smoke)
thanks for any help
thanks for any help
