  2. Dismiss Notice
Start up judder, help!
jri91 May 3, 2017
  1. PeteS307
    PeteS307 Registered User
    12
    Seems like there's a lot of causes for this judder on start up. I recently paid for a manual carbon scrape and it sorted the issue out it for a short period of time but now its back again.. feel like banging my head against a wall.. Can't think of anything else that could cause it apart from already mentioned on here?
  2. Avatar
    snack-media
    Advertisement
  3. Rideen
    Rideen Registered User
    1,152
    369
    Well, I have never gotten to the bottom of it, I've let the new owner have headaches with it.
    Possible list of causes is long but here it goes:
    • Glow plug(s)
    • Injector(s)
    • Battery
    • Starter motor
    • Cracked cylinder head
    • Bad compression
    • Timing
    • Engine mounts
    • DMF
    • Gearbox (if clutch is not pressed when starting)
    PeteS307 likes this.
  4. millsy4002
    millsy4002 Registered User
    296
    98
    Add bad earthing to that list, that was my cause
  5. aqibi2000
    aqibi2000 Registered User
    953
    160
    43
    Mine has the exact same symptom of metallic noises when sat overnight and smoke. I'm more than convinced from my own research that it's the exhaust cam advanced timing causing this. I'll be adjusting the cams sometime this week and get back
  6. Rideen
    1,152
    369
    This seems very likely, a very experienced mechanic asked me if I ever changed camshafts (which I did) and he said this could be the cause since I've put reinforced camshafts with the new cylinder head. It's worth a check for sure.
  7. PeteS307
    12
    Not sure what you mean by metallic noises lads? I'm getting a little smoke from the exhaust and the violent juddering on start up from mine. Getting the DMF checked today.. (clutch press to start) I've noticed a knocking sound that can be felt through the bottom of the car while holding on biting point.. it's exaggerated when holding the clutch going up an incline/hill.
  8. Rideen
    1,152
    369
    I would advise checking for axial play inside the gearbox as well as this can show the same symptoms as failing DMF, people change DMF and it continues happening = axial play inside gearbox.
  9. PeteS307
    12
    Thanks I'll take a look at this also today.
  10. Marek196c
    Marek196c Gilera Runner / A3 Sportback
    828
    probably injector leaks into combustion chamber, if you starting it and judder, turn it off and start again, should start normally.
  11. jri91
    jri91 Registered User
    47
    Hi bud, booked in for diognostics next week.. Ill keep you posted!
  12. Avatar
    snack-media
    Advertisement
  13. jri91
    47
    A few things i noticed this morning as car took a few trys to start up...
    1st attempt - judder
    2nd attempt - automatic lights failure symbol appeared
    3rd attempt - automatic lights symbol gone, car started but radio was off?
  14. Rideen
    1,152
    369
    My car used to do this as well. Randomly throwing auto lights error when they were working properly.
  15. Svenedin
    Svenedin Registered User
    700
    519
    93
    Surely everything is pointing to this being electrical (more likely than not)? There may be other problems as well. The OP hasn't said that he's changed the (sounds very old) battery or even checked the terminal and earthing connections. This would be a good start.....Theres no point changing glow plugs yet until they are tested with enough power!
  16. jri91
    47
    I do feel there may be more than one issue here
  17. Marek196c
    828
    Can be, but it's all about diagnose them (by checking) and eliminate.
  18. jri91
    47
    Had it looked at today, apparently its 99.9% the dual mass flywheel?
  19. jri91
    47
    So ive looked back at my old paper work for the car and noticed i already have had the dmf done before so as per my last message the garage i went this morning must be talking rubbish?
  20. Marek196c
    828
    do you hear rattling other than judder when pressing or depressing clutch while driving?
  21. jri91
    47
    Its automatic
  22. Marek196c
    828
    how you could get done dmf then. automatic got torque converter not clutch itself (unless dsg that got dual clutch but still net dmf). can be also bolt from flywheel loose
  23. Rideen
    1,152
    369
    I changed 2 DMFs in 2 years on old 2.0 TDI manual. And I've went with the most expensive DMFs, Sachs or LUK they were I think.
    PS: DSG is a twin shaft twin clutch preselector automatic and does need a DMF to protect the transmission from too much sudden torque transfer.
  24. Marek196c
    828
    sachs is provider of the oem parts, luk is cheaper and seen much more negative opinion about it.
  25. Rideen
    1,152
    369
    Just found old bills, one was Sachs, the other one was LUK. LUK was more expensive though @700 Euros.
  26. Marek196c
    828
    lol 2 years ago when I was looking for mine (manual) sachs was more expensive (like luk was 300£, sachs 400£) as well the old one (audi oem) was sachs as well. But as far as I looked after it in forums, opinions etc, in 90% sachs was better quality and more durable. however dunno about costs of automatic ones.
