Staining from trouser belt on seat leather
jdp1962
Grumpy Old Man
I’ve just finished cleaning and conditioning my S4’s seats with Gliptone Liquid Leather, and there’s some discolouration on the driver’s backrest where my brown leather belt comes into contact with it. This is the first time I’ve not been able to remove a mark using Liquid Leather but it just won’t budge. Does anyone have any ideas or suggestions?
95DD69A6 1EFF 49DB B223 5AC1F537A885
89622C48 47B9 4F47 9698 9838DDCE6AC9
Taxboy
That could be worth a punt.
Be careful with these they are abrasive and you can risk going through the coating. I would try another leather cleaner before going down that route. I use Dr Leather, this is not to say it will take it out but might be worth a shot. I have also found their customer service to be good so you might want to contact them first
Sent from my XT1032 using Tapatalk
jdp1962
Grumpy Old Man
@Taxboy , thanks for that; I'll make some enquiries.
T-Cut King !
You did try to clean the stain using a leather brush?
Try a bit of alchemy, by mixing some bicarbonate soda and leather cleaner together, clean using the brush
jdp1962
Grumpy Old Man
I did try with a brush, albeit not with the bicarb soda combo. Have spoken to Dr Leather; they say it's the "dreaded dye migration", so I really need to do some more research to see if I can undo that. If I can, at least I know I can block it for the future, but first I need to undo it.
T-Cut King !
Use a tiny bit of bicarb then seal the seats with Swissvax leather glaze it was going cheap on amazon
jdp1962
Grumpy Old Man
So, I've treated it with LTT Leathercare's two-stage dye transfer removal process, and then applied two coats of Leatherguard Protector.
It's improved it, but some staining is still there. I suspect I left it untreated too long.
