  2. Dismiss Notice
Squealing brakes?
Smickers Jul 31, 2017
  1. Smickers
    Smickers Registered User
    46
    I’ve got just over 8k on the clock and when I brake, just as I come to a complete stop, my brakes squeal like a banshee!
    Any ideas what would cause this, and would it be covered under warranty?
  2. Avatar
    snack-media
    Advertisement
  3. cuke2u
    cuke2u Well-Known Member
    12,914
    5,244
    Shims behind the brake pads possibly missing their graphite grease. Dealer should be able to rectify...
  4. Retroman
    Retroman Audi A3 2010 Sportback 2.0 TDI 170 (CBBB engine)
    1,250
    407
    New OE brakes should be silent - I would guess at some sort of contamination e.g. grit. I would refer it to the dealer on a new car like yours.
  5. TripleD
    TripleD Audi S4 Avant Owner
    819
    300
    if it's only just started squeeling then it's probably a stone caught in the disc guard.
  6. ToastMan
    ToastMan Registered User
    I've had dealer replace pads for free before due to squeak, then new set began to squeal too. Ultimately went with ceramics to resolve the issue.
  7. Gazwould
    Gazwould Registered User
    7,537
    3,047
    Which ones ?
  8. Bungle17
    Bungle17 Registered User
    58
    15
    I'm circa 16-17k now and have had a squeak for about 750 miles, just not had a chance to take it in yet! Hopefully something will be covered under the warranty- will report back once I finally get it to the dealers.
  9. SMI77
    SMI77 Australia
    521
    264
    Which brand 'ceramics'? Product code? Front/rears?
    For a B9 S4, or?
    Any info. would be appreciated.
  10. cuke2u
    12,914
    5,244
    I wonder if heavy and excessive braking can lead to the pads becoming glazed?
  11. Daggerit
    Daggerit Registered User
    3,188
    1,630
    I have a friend with a B7 RS4 that had the same issue. Pads were shot and disc were juddering and showing signs of warping after a couple thousand miles of not excessive use. Audi replaced the discs and pads a handful of times before they realised it would be cheaper to install the entire front ceramic brake setup and he's had no issues since. I think that it's on 50k miles and the discs are still going strong!
  12. Avatar
    snack-media
    Advertisement
  13. Smickers
    46
    After them finding nothing wrong with the temperature gauge and brakes a month ago, I drove off only to find them still faulty on the way home. Had to wait a month to get another appt. Left in this morning and they've now carried out a software update, and cleaned the brakes to find them still squeaking on the road test.
    They suspect faulty pads/discs and I'm waiting for a decision to see if they'll replace this under warranty.
  14. Snake Pliskin
    Snake Pliskin Well-Known Member Supporter
    4,592
    6,836
    This is quite alarming.
    Many of us RS3 owners have been plagued with low speed brake squeal and warped discs.
    I thought the issue was relating to the RS3 only - but seeing this post suggests not !
    I think the root cause of the squeal is the pad material used (OEM AUDI) and that may be the case here with your cars.
    Many owners have replaced OEM pads / discs with other brands, having got that fed up with repeat issues.
    One quick way you may be able to check if it the pads.
    Have you looked at your discs to see if there is a lot of pad residue on them.
    If so, pressure wash the discs when cold & see if loads of debris comes off.
    Then take the car for a drive and see if the squeal has gone.
    I have to clean my discs on a weekly basis because of the re-occurring squeal.
    Audi have fitted dampers but this only masks it for so long.
    Longer than a week without washing and the squeal returns.
  15. Smickers
    46
    They replaced both the discs and pads under warranty and have carried out a software update to stop the spurious temperature readings. They've also carried out a shoddy vac and wash and I've found this damage, that I certainly didn't cause :(
  16. Daggerit
    3,188
    1,630
    Ouch, that's quite the scratch! :dizzy:
  17. cuke2u
    12,914
    5,244
    Another victim to the poor valeting Audi seem to have these days. Take back and kick off...
  18. Snake Pliskin
    4,592
    6,836
    Jeeeeeeesus why do they think you'll accept the car back with damage like that ?
    Shocking quality control isn't it.
  19. Smickers
    46
    They asked if I wanted a wash and vac. Didn't realise they do it with a scouring pad!
  20. cuke2u
    12,914
    5,244
    From what I have seen and experienced that's not far off what they use...
