SQ5 SQ5 Stage 1 Dyno results
Rick @ Unicorn Motor Dev. Sep 28, 2016
  1. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,337
    673
    After Custom map, some serious pull :)
    Rick
    paul wev and AudiSpy like this.
  2. Avatar
    Google AdSense Advertisement
  3. paul wev
    paul wev Member
    62
    [​IMG][​IMG]
  4. paul wev
    paul wev Member
    62
    That's with a Dtuk tuning box
    RSS-S3 likes this.
  5. Rick @ Unicorn Motor Dev.
    1,337
    673
    Very good, do you have an AFR plot? I really lean this out at 4k as brick like aero of an SUV generates high EGT's
    Rick
  6. paul wev
    paul wev Member
    62
    I honestly don't know what you mean, it's just a plug in box?
  7. Rick @ Unicorn Motor Dev.
    1,337
    673
    Ok sorry, I will try and explain.
    The tuning boxes work by increasing fuel pressure, so that you are constantly injecting more fuel than the ECU thinks. DIesel engines are really quite crude, even the latest tech in the SQ5. More fuel = more power. But it has its side effects in that too much fuel will raise exhaust temperature and internal smoke will dramatically reduce DPF life.
    AFR - air/fuel ratio is a measure of how much fuel the engine is burning. I asked for a graph because quite often the tuning boxes put in so much fuel that they kill DPF's.
    With a remap, we control this very precisely The above plot is a very safe calibration. We can run much more, but that would require a richer mixture.
    Rick
    paul wev and desertstorm like this.
  8. paul wev
    paul wev Member
    62
    Thanks for the explanation, but I'm using the box so I don't get a td1 code (something like that ) on my ecu , and I take off the box when I take it in for a service.
    RSS-S3 likes this.
  9. Rick @ Unicorn Motor Dev.
    1,337
    673
    Yes I understand.
    With a remap you won't get a code on for a service. only for warranty work
  10. paul wev
    paul wev Member
    62
    I'll never know when I'll need warranty work done, so not worth the risk in my eyes. Know what I mean?
    RSS-S3 likes this.
  11. thesmileyone
    thesmileyone Active Member Audi A3
    536
    55
    How can aerodyamics of the car affect EGT's?
  12. Avatar
  13. chazd
    chazd Active Member
    535
    84
    Here is my superchips map
  14. Rick @ Unicorn Motor Dev.
    1,337
    673
    Power required is greater for a given speed. Therefore more fuel burnt and higher temperatures.
  15. thesmileyone
    536
    55
    Still don't understand how aero can directly affect EGT's?
  16. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User TDi Audi A4 Audi Avant Owner Group quattro
    6,823
    3,271
    The weight of the vechicle and the increased frontal area means the engine has too work harder to achieve and maintain speed especially at higher speeds.On a dyno an SUV and a saloon car with the same engine with the same map would perform the same with the same EGT's.
    In the real world driving at speed the SUV will require more power to accelerate and maintain any speed than the saloon car because of aero loads.
    paul wev likes this.
  17. SteveMcB
    SteveMcB Well-Known Member Team Sepang SQ5 owners group Audi Cabriolet Owner Group
    855
    451
    Hi Rick, have you had the chance to work on an SQ5 plus yet - 340 bhp with 700nm? If so would be interested to know if the tuned numbers are different from the 309bhp. Cheers.
  18. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,868
    958
    What other beneficial tuning mods can you do the to the 3.0TDI SQ5?
    I am considering changing to a PFL SQ5 TDI sometime next year coming from my Stage 3 S3
    I'm of the opinion a ECU and TCU remap would be the first port of call (revo for example) and some sort of turbo back exhaust and panel filter/intake?
    Any other options?
