- Joined
- Feb 4, 2016
- Messages
- 345
- Reaction score
- 52
- Points
- 28
Now an issue with both front doors on a 2020 SQ5.
When going over slight bumps and uneven road, you hear the rubber making a noise which is annoying
If you were to push your frame on the car door at the top in, you'll hear what is annoying us, doing this basically forces the noise to emit when parked.
It's rubber rubbing off of rubber tight together, and causing a clicky, creaky (hard to explain) noise, which we thought was the window vibrating, turns out its actually the door seals.
Car is going in around mid November, so will report back if the issue is resolved.
