GeoffDunk
- Joined
- Jul 11, 2012
- Messages
- 1,301
- Reaction score
- 400
- Points
- 83
- Location
- Attleborough
- Website
- www.gdluxurytransport.co.uk
Has anyone experienced spurious oil level warnings with the V8 S4?
I know my car uses oil and I accept that fact as I love the vehicle but between real top-ups my low level oil warring pipes up 5 or six times but when check the oil level is still at an acceptable level.
This is really annoying; I have changed the oil pressure switch £72, rocker cover gaskets and I know the rear engine seal leaks but its not a case of the oil actually low as such but false reports. I have noticed once I check the oil as in pop the bonnet and pull the dipstick the warning goes away.
Also, in hard left turns I get the brake level warning flash up in red for the 5 or 5 seconds and then once I'm driving straight again it goes out. The warning only appears under hard left cornering. Break fluid level is spot on by the way.
Hopefully some of you guys may know or have seen these two problems before.
Geoff
Geoff
