Sport to S Line suspension.
Kayobong Aug 10, 2018
  1. Kayobong
    Kayobong Active Member Team Monsoon TDi Audi A3
    288
    172
    43
    Is it possible to change the suspension on an A3 8V Sport to an S Line spec suspension, if so how difficult is it and is it really worth it? Also is it difficult to get a hold of an OEM S Line suspension?
    Thanks.
  2. Avatar
    Google AdSense Advertisement
  3. Tashfeen
    Tashfeen Moderator Staff Member Moderator Team Glacier TFSI Owners Group Team V6 VCDS Map User Team Scuba Supercharged Audi S4 Audi A3 Black Edition quattro
    5,721
    11,740
    My personal go to would be the Bilstein B12 Pro kit, which comes with Bilstein B8 shocks and Eibach Pro springs. On the standard Sport suspension it would give you a small drop on fronts and rears.
    A3 Sport - 26.5"
    B12 - 25.5"
    In terms of ride harshness it won't be much different to Sport suspension but it would be a lot comfortable with improved handling.
    B12 is slightly expensive kit and you can go with only Eibach Pro springs to improve things slightly which would be slightly less expensive option.
    Apart from B12 there are other slightly less expensive options available as well, which I am sure others will be able to contribute.
    Kayobong likes this.
  4. Kayobong
    288
    172
    43
    Oh, that sounds pretty good actually, I'll take a look. I want to keep the look as stock as possible, so I take it the drop wont look too noticeable externally. Do you know the height of the S Line suspension?
    Tashfeen likes this.
  5. amb66
    amb66 Member Team Daytona TDi Audi A3 Black Edition S tronic
    56
    30
    It's a centimeter lower than sport if memory serves me correctly. Same height as non mag ride S3 suspension.
    Tashfeen and Kayobong like this.
  6. dp_motley
    dp_motley 2012 A3 1.6 TDI
    773
    189
    43
    Is there a noticeable comfort difference between the sport and the s-line suspension on 8V?
