I think I just downloaded as CSV. So from https://www.pocketgpsworld.com/modules.php?name=Cameras#compatibilityHi Everyone,
I've just picked up my new S3 and i would very much like to to add Speed cameras POI. I read through all the tread but i'm still don't understand how to do it. I have an account with Pocket GPS world, but i don't know where and which files to download.
Please help...
So i tried to upload POI for speed cameras on a facelift car with mixed results.
I have been sucessful with creating the files for each speed canera and then sending them to the car. However you cant alter the zoom level.
I have therefore followed the guide, downloaded the data and changed the zoom level in the categories file. Placed the two files as per below onto both a memory stick and a USB stick to create a manual update.
PersonalPOI
Metainfo2
Each and every time I get the following messages:
I know others have been sucessful on FL cars so what am I doing wrong? I have tried different SD cards , different USB sticks and nothing works.
Many thx
Jungle
Check post #276 - it is because the checksums and file size of the original categories.pc file do not match those in the hashes.txt after you have edited it.
You only need to change the values that are related to catagories.pc as that is the only file you have edited. In hashes.txt there will be a line that looks something like:Aaah.. OK so as zoom level is changed to 30 from 9 things don't match.
Ok thx @TonkS3 for pointing me in this direction. I have used Hashtab to verify the checksum of the file and you are correct it is different. However how do I change the value and where exactly is this done? There are multiple checksum figures in the hashes.txt file if I view using notepad and none of them seem to match the figure reflected in properties, so I am a bit lost what I need to change and how to do it.. Although atleast I now know where the problem is !.
I presume that as I have downloaded all of the camera types into one large file I can just change the checksum to match in one place? Or do you have to download each and every camera separately and change checksum info for each one ??
Apologies if these seem daft questions, but checksums / hash values are a whole new ball game for me.
Many thx Jungle
FileName = "categories.pc"
FileSize = "3161"
CheckSumSize = "524288"
CheckSum = "DA9F37FBF2FB634C85FE8744223B2EB677B72305"
You need to change the filesize and checksum lines.
Enter the bytes figure from the catagories.pc general tab of properties for filesize.
Use the SHA-1 hash value for catagories.pc and replace the existing value that is in hashes.txt
Hope you get it sorted![]()
Do you have google earth maps? does it show the iconsThank you for the clear guide. I edited just the line that mentioned the categories file in the hash file using notepad. As you stated I changed the file size and then copied the new hash value and bingo it works !
Thx v much!
Jungle
Need a software engineer to come and fix it haha, seems like something has changed on the PocketGPS website though as from Mcadddy's source code it says....Yes its a shame the Mccaddy file no longer appears to work. The error message I get is:
// Check to see the download link exisits, failing this check is the first indicator
// that someting has changed on the PocketGpsWorld website
if (!loggedInPage.Contains("<a href=\"/modules.php?name=Cameras\" class=\"sidemenu\">Download Speed Cams</a>"))
throw new WebException("Unable to find download link at PocketGPSworld.com, Please report error 1000 to developer");
PFL MMI Units will not display the Cameras when in Google Maps Overlay Mode however FL MMI Units willYes have google earth, but u need to use standard map setting/view to see speed cameras. Google maps does not overlay POi speed cameras.
All, reading through this, I am confused (not difficult) as to whether I can install the camera DB from pocketgpsworld (paid the £20) onto my MY18 Q5 with Standard Navigation. Can someone clarify please if they don't mind?
Depends if your ‘ standard nav’ on Q5 allows you to install updates. If its an SD card or DVD based system the above thread/ posts are not for you. If its a hard drive based system and you have previously been able to install updates then maybe you will be able to use the POI route.
Jungle
I raised an issue on github and mcaddy has fixed the issue so v0.9.1 is working without errors
It can be downloaded here.. https://github.com/mcaddy/audipoi/blob/master/Releases/SpeedCameraToPoi/v0.9.1.zip?raw=true
I haven't tried to upload it to my car, but it seems to have downloaded the files etc.
Deffo seems much quicker than doing it manually!Thats great as it such a PITA do download them all manually. McCaddy is so much faster. Superb!
Thx
Jungle
I have just had the software on my MMI updated to fix the missing subwoofer control issue. It seems that now I have Speed Camera POI displayed on google maps not just the generic maps !
Was on Ver. 0679 I am now on Ver. 1168
FileSize = "3161"
Can't help in the SHA business as I've not had that issue but at least on PFL I didn't have to remove the existing cameras (not even sure how!), I could simply update and it worked...Im having the same problem always comes up the update was interrupted, i've changed the file size and SHA-1 there all correct still nothingi already have the cameras installed as POI but wanted the zoom level changed, would i need to remove the existing cameras first then try the upload again?
Any help appreciated
So most of us are subscribed to this website which gives us the list of cameras, think you create a login then pay to be a member. £10?May someone help me with this? I am so confused and I am not tech savvy. I would legit pay someone £20 for helping me get this speed camera detector on my MMI.
Anyone?![]()
Then download this application from here.. https://github.com/mcaddy/audipoi/blob/master/Releases/SpeedCameraToPoi/v0.9.1.zip?raw=true
Then you can run the application (need Windows computer) , it's simple, you just login and it creates the files you need. Then you need to put these files onto a USB stick / SD card, plug into car. Then in the settings somewhere you can find the option to update the system. It should then detect the files on the USB / sd card and should be done.
On some cars though you can send the data over Audi Connect but I'm not sure on which cars and how this is done.
Hopefully not too vague, not at my computer to double check the process.
Anyone?![]()
There has been discussion on the sound notifications, not sure if there is something in the settings on the MMI for FL cars, I don't have one so can't comment.Thanks oli356,
Ive just successfully installed all the files and all the speed cameras icon are showing up in my google maps using the links above. However i come across a problem where sometime when i get to a camera location the icon does not show up on my main or virtual cockpit display unless i change the zoom level and it then reappears again. I'm i done something wrong?
Also is it possible to set a sound notification when you almost get the a speed camera? If so how can this be done?
So my zoom level is set to 30 and I haven't had any issues. I think the mcaddy app makes it something different, so it might be worthwhile trying 30.
You need to edit the categories.pc file which is in ... PersonalPOI\Package\0\default , just open it in notepad.
and then make all references of zoomlevel max to 30.
<zoomlevel max="30" min="0"/>
BirminghamWhere do you live.. roughly
Sent from my iPhone using Tapatalk Pro
Hi can you PM me? Do you have whatsapp or any instant messaging apps that we can talk?So most of us are subscribed to this website which gives us the list of cameras, think you create a login then pay to be a member. £10?
