  2. Dismiss Notice
spark plug problem
hydro s3 Sep 12, 2017
  1. hydro s3
    hydro s3 S3 amk Team Ming Blue Audi S3
    1,162
    321
    20170912_144504.jpg Hi
    My car started to shutter pretty badly so i put on my reader but no codes where there. So i decided to take out the plugs and as you can see from the picks 1 is not looking so good. They have only done about 3500 miles since they where last changed. The one on the right is from cylinder 4.I changed them out for a new set to day but problem is still there. Can any one suggest what i should try next? Car is not driveable the way it is.
  2. Avatar
    snack-media
    Advertisement
  3. <tuffty/>
    23,967
    5,356
    Any chance of a pic thats in focus?
  4. hydro s3
    1,162
    321
    20170912_171035.jpg Sorry shakey hands.
  5. Retroman
    Retroman Audi A3 2010 Sportback 2.0 TDI 170 (CBBB engine)
    1,177
    382
    The one on the right is covered in black carbon deposits which suggests an incomplete/impaired combustion. As a forum guess I would put £5 each way on the ignition coil. Often impaired ignition coils give either ambiguous "misfire" error codes or nothing specific at all.
    They also look quite oily?? After just 3500 miles they should look as fresh as a daisy.
  6. hydro s3
    1,162
    321
    The four came out pretty oily number 2 especially but number 4 was black and caked in carbon. What would be causing all the oil? Is there a gasket i should change to stop this or is this worn rings.
  7. NickVC
    NickVC Member
    54
    valve cover gasket is shot
    Retroman likes this.
  8. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    7,154
    3,536
    Does the engine actually use oil. I used to have an 1850 dolomite many moons ago that had a bad oil consumption problem that caused similar problems with the plugs. How many miles has the car done.
  9. superkarl
    superkarl MAN OF STEEL
    10,031
    2,670
    Do a compression test
  10. Retroman
    1,177
    382
    The oil - sounds like what NickVC said is right. I don't know your engine but with most OHC engines the spark plugs are positioned down in little holes or channels and oil leaking from the cam/valve covers can cause a puddle of oil around the spark plug. However, as your car still misfired immediately after fitting new plugs I don't reckon the misfire is caused by oil fouling either from a cam/valve cover gasket leak or some internal engine oil problem. Still good practice to cure a gasket leak though.
    In the top picture the plug with cleaner spark end electrodes looks like it has some electrical corrosion deposits on the part which plugs into the ignition source. Does your car have HT leads from a single coil pack or individual coils on each plug? If the former, what is the condition of the leads? After 10-years or so there is no harm in replacing them.
  11. hydro s3
    1,162
    321
    Thanks for the replys everyone. I will get a compression test done and see how that turns out. Then ill try the leads and new rocker cover gasket. The car isnt useing much oil my have to put in a bit each month but not any great amount.
  12. Avatar
    snack-media
    Advertisement
  13. Fordy51
    Fordy51 New Member
    Might be worth using the right plugs too, those look way too projected into the bore and are 6kohm.
    Pfr6q are 1kohm and aren't as projected
    Use PFR7Q if you want a grade cooler
    Jay 01 s3 likes this.
  14. superkarl
    10,031
    2,670
    Well spotted
  15. hydro s3
    1,162
    321
    Those plugs where put in the car when i got it serviced so didnt think id need to check they had used the correct one's. I only had them out cause of the problem. It still does not explain why cylinder 4 was so sooted. I have it booked in for friday at a different garage for a compression test and a look over. I will point out to them that the other garage have used the wrong plugs.
