  2. Dismiss Notice
Spark plug and remover tool
a3sline_nottingham Aug 2, 2012
  1. a3sline_nottingham
    a3sline_nottingham Registered User
    Hello all
    Am Having issues with my a3 Sline 56 plate 2.0 tfsi as it judders on accelerating from starting cold until it hits 90 degrees. From their it's fine so in going to change the spark plugs to see if it stops the above
    Can anyone recommend me some good plugs and a tool to remove them.
    Ta
  2. Avatar
    snack-media
    Advertisement
  3. antmax7
    antmax7 Registered User
    295
    have you had it checked for codes???
    could be lots of things
    has it got the new coil packs fitted from the audi recall??
    also spark plugs would perform better in cooler conditions anyway it's simple physics
  4. rickypj
    rickypj Registered User
    Check with Audi if it's had the coil pack recall. I had the same issue and the recall sorted it. Just ring them and ask what recalls are outstanding. 😊
  5. a3sline_nottingham
    Just rang them and they will happily take a look, so booked it in for next Friday. Glad I asked the question
    They did say there is a recall but unsure if it will rectify the problem but I'll leave it in their 'capable' hands
    Cheers for the help
  6. MrLapou
    MrLapou Registered User
    1,232
    120
    Could be a temp sensor prob.
    I use a box spanner,extending its length using a smaller box spanner which slips inside the larger one.
    Then withdraw the plugs with one of these grippers.
    Easy pezie..
  7. antmax7
    295
    Or just use a proper spark plug socket which holds the spark plug for you:thumbsup:
  8. moag
    moag she's no d-turbo
    817
    35
    Socket wrench, extension bar and deep spark plug socket (21mm IIRC) is all you need
  9. a3sline_nottingham
    Ok, recall of coils has been completed and new ones fitted, changed to Bosch iridium spake plugs at the same time. Has made a difference, juddering is about 60% better. Plugs were a bit sooty an the second one was all oily. Could it be a seal causing this ??
    Used the guide on here to remove engine cover and do the plugs myself
    Next job is the air filter. Going to buy one of eBay for about £7 and do that at the weekend. Any one got a link on replacing the air filter on a 56 2.0TFSI
  10. NHN
    31,823
    2,347
    Always best to use a proper spark plug removal tool as it incorporates the rubber cushioning to holder the plug to remove aswell, rather than relying on other tools to lift the plug out, if something of another tool was to fall into the cylinder, you're not gonna be happy, whereas these tools are almost fool proof.
  11. a3sline_nottingham
    Still juddering after plugs and cool pack have been changed
    Next is the air filter??
    Any other suggestions for me to try next
  12. Avatar
    snack-media
    Advertisement
  13. NHN
    31,823
    2,347
    Check new plugs for oil, if they have, then obviously there's an issue as it could be the oil is being burned up with the heat of the cylinder & leak seal/head etc are expanding with the heat & only when its standing cold its getting oil into cylinder, speculative as not seen/know the car, but stands to reason atm based on your reports.
  14. OCD-A3
    OCD-A3 Registered User
    118
    Also (if the new plugs are clean) try unplugging your MAF and go for a drive. Could be that the MAF needs to be cleaned or replaced.
  15. NHN
    31,823
    2,347
    I wouldnt clean the maf tbh, fairly sensitive, just replace if its this.
  16. a3sline_nottingham
    I'll unplug the maf, and report back, was totally unaware i could run it when disconnected...Yes NHN the second spark plug from the maf/turbo pipe had oil when I removed it. What's the price gonna be on getting the seal sorted??
  17. a3sline_nottingham
    Looks like its a valve seal or stuck injector on the second cylinder....
  18. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    6,883
    1,844
    Ouch, not pretty. How have you concluded that? Bore scope?
    I was going to say check fuel filter, and possibly try fuel line cleaner, but might be worth checking injector spray pattern if you get them out (change seals whilst they're out).
  19. a3sline_nottingham
    I've it it back with Audi on Friday, they have said they wil put it It on a diagnostics machine and do a compression test. I'll update after.
    I'm sure fuel filter would affect all cylinders right?
