  2. Dismiss Notice
Space Saver Advice?
V6Tom Nov 17, 2020
  1. V6Tom
    V6Tom Active Member VCDS Map User
    150
    52
    Good evening Gents,
    I run 20 inch alloys with 255/30 R20 tyres. My space saver is a 19 inch with tyre 125/70 R19
    So I did some calculations
    so to my confusion my 19 inch space saver is bigger than my normal 20 inch wheel. so are space savers supposed to be larger than the full size wheels?
    I had a blow out recently and I was told you cant run a wheel smaller on a quattro? messes up the abs or something
  2. Avatar
    snack-media
    Advertisement
  3. joinerman
    joinerman Registered User
    14,709
    640
    It winds up the transmission
  4. I'm Just Rob.
    I'm Just Rob. Moderating or something, Staff Member Moderator Gold Supporter VCDS Map User
    15,471
    7,073
    rim size and tyre size are not really the issue, well they are but its the " Rolling Circumference " that is crucial on AWD cars etc.
    all wheel/tyres need to have the same rolling circumference otherwise you get adverse effects on the diffs etc, all wheels need to be travelling the same distance , there is a very small amount of variation , but it is small.
    So how you get to the same data for the spare is up to you, just ensure you keep things all the same.
  5. jdp1962
    jdp1962 Grumpy Old Man
    9,776
    4,339
    When you say your "normal 20 inch wheel", are you saying these are the OEM wheels the car came on from new? Or have you changed the wheels from the original and use "normal" in the sense on "not the space-saver"?
  6. V6Tom
    150
    52
    Sorry gents.
    My car came with 19's at 30 profile and my 20's are 30 profile.
