Made another thread but cant seem to find it.
I have a intermittent smoking problem on idle, Seems to come and go mainly when warm but can also do it when cold. Some days its preety clean and clear other days it chucks loads out.
Seems to be a grey/white colour maybe with a blue tinge.
I have swapped rocker covers with a mates as read somewere the breather (pcv) can become blocked and cause the issue, this made no diffrence
Turbo should be ok i imagine as it is less than a month old.
Inlet manifold has been swapped for a bkd one without the flaps and fitted with new gaskets (the engine oil washes past a gallerie in the mani on its return to the sump)
Egr has been deleted along with egr cooler and also decatted
Does have a hybrid fitted but no oil in downpipe or boost pipes (bare the usually small amount which these car breath).
I am now starting to get to my witts end with this issue and if it dosent get solved i will be breaking the whole car down for parts which is a shame.really as it is immaculate with 1000s spend on mods
I plan on doing the injector seals in the morning as a last ditch effort to cure this smoking issue.
The car runs fine, idles well and pulls like a train, apart from if the revs are held at around 1600ish rpm then it seems to either miss or shudder, failing injector maybe or just seals
My indy recons seals so i will do them myself 2moz and report back.
Any help info or advice on this would be much appreciate
