Skoda vrs arb droplinks, help!!!!
Gregb278
So i have got Ap coilovers on my car and want to bring it down more so I have got a vrs arb which goes under the shafts. I can get some adjustable drop links of a mate just wondering if these will be long enough or is it better to just get the droplinks off a vrs?
From what I can remember, VRS drop links can be sometimes too long on some coilover kits, Mercedes Vito drop links are usually used.
You don't happen to know the length of the vito droplinks?
Sent from my E6653 using Tapatalk
What? Never heard of this at all.
use the droplinks for the bar.
Under shaft ARB's should all clear fine when used with the corresponding drop links.
You'll also need to have struts with the arb mounting tab, as the VRS arb doesn't connect to your wishbones either.
Yeah I have got Ap and they have the eyelet on them. I always have some adjustable droplinks just not sure if they will be long enough
they're just wrong. the adjustable drop links are for over shaft bars which attach to the wishbone, and they don't work on them either.
use the correct drop links for the bar you're using. they're about £20 a pair on ebay.
Right I will get on it now cheers mate
Cheers guys got some s3 droplinks
643
662
