  2. Dismiss Notice
  1. Super Nintendo Chalmers
    Super Nintendo Chalmers Registered User
    287
    47
    I've removed the side skirts/stone guards from my A4 B8.5, managing to also remove 95% of the 3m double sided tape.
    I've hand washed the car, two bucket method and snow foam, but that's clearly not enough
    A bit of the 3m tape remains as well as some general ****, any suggestions on how best to clean?
    New skirts going over the top, but would like to have it clean before I do so!
  2. Avatar
    snack-media
    Advertisement
  3. RS03_SEN
    RS03_SEN Registered User
    544
    352
    Tar and glue remover possibly.
    Sent from my GM1913 using Tapatalk
  4. Adam14
    Adam14 Registered User
    2,184
    2,033
    Tar and glue remover, may need a plastic scraper to help remove more of the built up glue.
    Sent from my HD1913 using Tapatalk
  5. RS03_SEN
    544
    352
    Are skirts easy enough to remove? I hit a high curb in my RS3 and took a piece out of one of mine.
  6. Super Nintendo Chalmers
    287
    47
    Bit of a ball ache as i was new to it, but a with a bit of elbow grease, WD40 and a plastic blade and they're off! There are clips but it was mainly held on with double sided 3m tape https://www.google.com/search?q=3m+...hVnUhUIHb5UD18Q_AUoAnoECA0QBA&biw=927&bih=949
    Which year is your RS3? I've had a quick look at the various platforms and i'm not sure if they are attached in the same way as they are on the b8 A/S4s
    Have you checked if there are screws at either end of the skirt in the wheel well arch?
  7. RS03_SEN
    544
    352
    It's 2015. Haven't looked, to be honest. The scuff is well hidden but if it's easy to do I'll sort it, if not, it can stay as it is.
  8. josul
    josul Registered User
    354
    283
    You could try to just use your WD40 to remove the glue residue.
  9. Super Nintendo Chalmers
    287
    47
    Yep that's what i'm going to go for, just need to get some time and dry weather!
  10. rafletcher
    rafletcher Registered User
    334
    79
    Goo-Gone is your friend....
  11. Super Nintendo Chalmers
    287
    47
    WD40 did the job in the end.
    Thanks for the suggestion.
    josul likes this.
