Should this have a bit of play in it....
S4_dan Sep 1, 2018
  1. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,843
    187
    This tensioner has a bit of play in it where the bolt holds it to the car (bottom left bolt). Even the bolt head moves slightly with the whole tensioner. There is a small rubber seal that sits behind the tensioner as per separate pic.
    My serpentine and air con belt snapped yesterday, air con compressor seized up with driving.
    Trying to fit a new belt and guide pulley but found this main serpentine tensioner has a bit of play. It's only held onto the block by two bolts, bottom left and at the top of the spring part. Is this correct?
    Cheers.
