  2. Dismiss Notice
should the hand brake come on automatically when you switch off engine
sunshinewelly Sep 4, 2018
  1. sunshinewelly
    sunshinewelly Registered User
    272
    144
    43
    I am sure my car (S4) used to do this but now i have to push the button to switch on handbrake.
  2. Avatar
    snack-media
    Advertisement
  3. Parklife
    Parklife Registered User
    134
    32
    Mine comes on automatically most of the time. There are occasions where it doesn't though.
    Sent from my CLT-L29 using Tapatalk
  4. cuke2u
    cuke2u Well-Known Member
    12,914
    5,244
    Quite, this has been noted before to be random but certain conditions have to be met first...
  5. shadenville
    shadenville Registered User
    19
    12
    Anyone know what, as mine never does it - and I’d like it to
  6. Startfromthetop
    Startfromthetop Registered User
    Interested in the conditions too.
    Wife’s golf mk7.5 (so awfully similar) does it all the time.
    My A4, with autohold, does it at best occasionally.
    Seems an incline triggers it.
  7. mojo555
    mojo555 Registered User
    351
    27
    My new S4 doesn't do it at all, my S3 did and my golf R did, both without fail every time with engine switch off or open door or take seatbelt off
  8. mojo555
    351
    27
    It really annoys me the S4 doesnt
  9. cuke2u
    12,914
    5,244
    My previous A3 did as does my current A4. The conditions that need to be met are within your car's manual..
  10. pierreluigi88
    pierreluigi88 Registered User
    218
    224
    43
    You can set it with OBDEleven so that park and handbrake are always applied when you turn the engine off
    rasA4 and RJ-8V like this.
  11. terminator x
    terminator x Registered User
    4,673
    5,321
    When parked up I press Park which seems to engage P but not handbrake. I mostly always have to press that too.
    TX.
  12. Avatar
    snack-media
    Advertisement
  13. Mortey
    Mortey Registered User
    24
    I put a post about this a month or so ago. It seems to be down to how much you push the brake pedal.
    I pulled slowly into a space went into a shop only to be called as my car had rolled forward and hit a barrier. It was lucky the barrier was covered in some advertising so there was no damage, but you would think this should be a standard thing.
  14. cuke2u
    12,914
    5,244
    Pressure on the brake pedal makes no difference to the randomness on mine.
  15. Happy Grumpz
    Happy Grumpz Well-Known Member Silver Supporter
    568
    706
    93
    Doesn't it automatically come on when you take your seatbelt off?
  16. Mortey
    24
    Definitely not when you take your seat belt off, I had got and started looking in a shop when it happened to me!
    I have found if I am going really slow and only lightly apply the brake automatic handbrake does not come on and so when you switch it off the hand brake doesn't either.
  17. cuke2u
    12,914
    5,244
    It is when you turn off the engine with the button, athough, if you are wearing your seatbelt, it will come one when you open the drivers door..
  18. Hammerhead
    Hammerhead Registered User
    123
    50
    I just turn the engine off, car goes automatically into park, never use the handbrake unless I was parking on a very steep hill
  19. terminator x
    4,673
    5,321
    I just stopped, no handbrake light. When I opened the door though it illuminated.
    TX.
  20. cuke2u
    12,914
    5,244
    A very quick way to destroy the park pawl by placing unecessary strain on the hook and its mechanism. You are placing the weight of the car on to a tiny piece of metal locked in a gear..
  21. Evil Derboy
    Evil Derboy Registered User
    959
    933
    93
    Agreed. Fine if on a level surface but not recommended on a slope.
  22. Evil Derboy
    959
    933
    93
    How? I’ve got OBDEleven and would like to do this.
  23. Concerned Cat
    Concerned Cat Age & treachery will always overcome youth & skill
    108
    59
    Last car, VW lasted nearly 60k with no problems putting in park. Stronger than you think.
  24. pierreluigi88
    218
    224
    43
  25. Evil Derboy
    959
    933
    93
    pierreluigi88 likes this.
  26. cuke2u
    12,914
    5,244
    Well it's your call however you are placing unnecessary strain upon the parking mechanism and the gearbox...
  27. Mortey
    24
    I think there is a difference between manual and automatic here. I have a manual and it will not automatically apply the handbrake unless I firmly apply the brake so the hill hold comes on, it will then apply the parking brake.
    Mine needs its first oil service next month so I will ask them, also about the ticking I seem to get, even though the engine, cooling and stereo is completely off....
  28. ub7rm
    ub7rm Registered User
    421
    222
    43
    I have an auto and as far as I can tell it has never automatically put the handbrake on when I switch it off. I don't have hill hold - i wonder if this is relevant.
    My mk7 golf applies the handbrake everytime I switch the engine off.
  29. cuke2u
    12,914
    5,244
    Life must be so boring for those where everything works perfectly ;-)
