Shaking while braking
Neo96 Sep 21, 2017
  1. Neo96
    Neo96 New Member
    New Audi owner 2016 A6- got it from a used car dealer with 30k miles on it. Im noticing a shaking when im slowly applying brakes. The dealer replaced the rotors as it was considered to be a warped rotors issue but the issue is still persisting and really annoying. He told me to try driving for another few miles till the brakes get used to the new rotors, but am not sure as its still not reducing. Did he misdiagnose the issue? Should i take it to a 3rd party workshop to check it out? Would love to hear from other owners
  2. Avatar
    Google AdSense Advertisement
  3. Retroman
    Retroman Audi A3 2010 Sportback 2.0 TDI 170 (CBBB engine)
    1,103
    361
    Those symptoms are typical of warped rotors. Car's is fairly new with low mileage so ruling out suspension/bearings. Did the technician fit new pads? Old pads may have worn unevenly and as result the gap from side to side might vary and/or be applying brake pad material unevenly to the new disc surface (rotors :glee:). Can't think of anything else:shrug:
  4. thawatchai2510
    thawatchai2510 Member
    92
    To breaking in .
    How to Break in a New Car
    There are plenty of ways to break in your new car. Some of them are the right way.
    It's a thing of beauty: A brand-new car, shiny and crisp. It makes you want to spend the whole evening walking around it. Pretty soon, the neighbors wander over to congratulate you—and to render advice.
    Break it in carefully, one says: "No more than 30 miles per hour until it has 1000 miles on the odo."
    "No," another says. "Drive it like you stole it, if you want it to be fast."
    Others recommend synthetic oil, or nitrogen in the tires, or a mouse-milk oil additive, guaranteed to double fuel economy.
    The ritual of breaking in a new car is part of the body of knowledge we refer to as conventional wisdom. It's not necessarily wise, and the technology of building a modern automobile has evolved to the point where a lot of "wisdom" is obsolete. Few cars specify a break-in procedure anymore, simply cautioning you to avoid extreme acceleration or extended idling for the first thousand miles or so, and there's little in the way of extra service up front. Some don't even mandate an oil change until 6000 miles. We think your new ride deserves better. Here are a few tip.
  5. Samuel c5 Q
    Samuel c5 Q Active Member Silver Supporter VCDS Map User
    618
    119
    43
    Check the slide pins for trueness. I had discs that kept warping because the slide pins were off. My issue anyway.
Tags:
