shifty_steve
Suddenly I've got a severe drain on battery, battery drains down in about 10mins - charged up overnight, connected up and tried turning over but virtually zero
Charged battery with a fresh (spare) diesel battery and again couldn't turn the starter over and drained down in minutes
The night before, the car went through a roller wash (first & last time) and so I'm left thinking it's got something to do with water ingress....but it seems dry
The rear lights and boot lock seem to be out of action now also
Could it be a short in the tailgate or something ?
Any clues would be a help, had an ignition fault to sort, prior to this but was due to investigate....here's the fault codes
appreciate your opinions
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8LZ1A017767
Address 01: Engine Labels: 06A-906-032-AUM.lbl
Part No: 06A 906 032 DK
Component: 1.8L R4/5VT 0001
Coding: 11500
Shop #: WSC 06435
VCID: 6ADD87E8166372489F8
WAUZZZ8LZ1A017767 AUZ7Z0Y1553515
4 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 -
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
P1340 - 35-00 - Incor. Correlation
17535 - Fuel Trim; Bank 1 (Mult)
P1127 - 35-10 - System too Rich - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0011266
Shop #: WSC 00011 000 00000
VCID: 2C5141F08C17AC78AD4
No fault code found.
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 H
Component: A3 KLIMAAUTOMAT 0101
Coding: 00041
Shop #: WSC 06435
VCID: 2D574CF4E70DA570BAA
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 4008
Coding: 01104
Shop #: WSC 06435
VCID: 458714545FBD7D3052A
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 980 E
Component: AB-KOMBIINSTR. VDO D12
Coding: 00444
Shop #: WSC 00001
VCID: 356764940F5DEDB0C2A
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15178
Shop #: WSC 06435
VCID: 2F6B56FCED01D760886
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
VCID: E0C965C0605FB818C1C
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8L0 035 186 A
Component: Radio D05
Coding: 00203
Shop #: WSC 06435
VCID: 2C5141F0DC17AC78AD4
End ---------------------------------------------------------------------
Friday,08,January,2016,14:12:54:07323
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0
Data version: 20140212
VIN: WAUZZZ8LZ1A017767 License Plate:
Chassis Type: 8L (8L - Audi A3/S3 (1997 > 2003))
Coding: 0011266
VCID: 2C5141F08C17AC7E17F-515A
Coding: 00041
Shop #: WSC 06435
VCID: 2D574CF4E70DA576001-25B2
Coding: 01104
Shop #: WSC 06435
VCID: 458714545FBD7D36E81-515A
Coding: 00444
Shop #: WSC 00001
VCID: 356764940F5DEDB6781-5178
Coding: 15178
Shop #: WSC 06435
VCID: 2F6B56FCED01D76632D-4F1E
6 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
01134 - Alarm Horn (H12)
49-00 - No Communications
Coding: 00001
Shop #: WSC 00000
VCID: E0C965C0605FB81E7B7-4B4A
Coding: 00203
Shop #: WSC 06435
VCID: 2C5141F0DC17AC7E17F-4B32
Coding: 11500
Shop #: WSC 06435
4 Faults Found:
P1297 - 35-00 -
Coding: 0011266
Coding: 00041
Shop #: WSC 06435
Coding: 01104
Shop #: WSC 06435
Coding: 00444
Shop #: WSC 00001
Coding: 15178
Shop #: WSC 06435
Coding: 00001
Shop #: WSC 00000
Coding: 00203
Shop #: WSC 06435
Coding: 0011266
Coding: 00041
Shop #: WSC 06435
Coding: 01104
Shop #: WSC 06435
Coding: 00444
Shop #: WSC 00001
Coding: 15178
Shop #: WSC 06435
6 Faults Found:
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
Coding: 00001
Shop #: WSC 00000
Coding: 00203
Shop #: WSC 06435
