  2. Dismiss Notice
Service notification
JohnStan725 Jul 23, 2015
  1. JohnStan725
    JohnStan725 Registered User
    147
    9
    Hi,
    Need some help on how to change the service notification time, do I use vag com? If so what's the procedure? IMG_20150722_220606.jpg
  2. Avatar
    snack-media
    Advertisement
  3. <tuffty/>
    <tuffty/> Badger 5 Edition...Its all about the flow... Staff Member Moderator
    24,336
    5,592
  4. <tuffty/>
    24,336
    5,592
  5. VAG-Slag
    VAG-Slag Registered User
    1,857
    443
    Do you just want to reset the service indicator or actually change how often it come on once reset?
  6. JohnStan725
    147
    9
    Thanks tuffty will check it out when I'm back at home, I'm wanting to reset it so it does keep coming on and yeah change it for when it next should come on :greyrs4:
  7. VAG-Slag
    1,857
    443
    If you just want to reset the light it actually tells you how to do it in the Audi A3 user manual... It's some sort of combination of pressing/holding/releasing the mileage button and switching the ignition on/off, the exact combination escapes me at this moment but it shouldn't be too had to find!
  8. JohnStan725
    147
    9
    Thanks Vag-slag! so its a pretty straight forward process? will surf the web see if i can find the method to reset this.
    VAG-Slag likes this.
  9. Erikn89nl
    Erikn89nl Registered User
    953
    388
  10. JohnStan725
    147
    9
    HI Erik, Will check this when i get home as i cant access youtube at work :/ thank you though!
  11. JohnStan725
    147
    9
    Erik I tried this method on the youtube video and no luck still keeps coming on :(
  12. Avatar
    snack-media
    Advertisement
  13. VAG-Slag
    1,857
    443
    Did you ever get this sorted mate? . . Here's what it says in the book:
    -Switch off ignition
    -Press button 2 (one by speedo) and hold while switching on the ignition. The display should now read "SERVICE!"
    -Press and hold button 1 (by rev counter) until the word "SERVICE!" is cleared from the display.
    Which is obviously slightly different to the video, worth a punt
    JohnStan725 likes this.
  14. JohnStan725
    147
    9
    Cheers buddy I have managed to do this with the method above it reset to 9300 miles.appreciate your help with this btw
