Service intervals
A4T Nov 28, 2018
  1. A4T
    A4T Member
    30
    Can anybody tell me where I can check the service intervals and required work at each service please? I'm past using Audi but for a while was asking them for the work to be completed each time. I think they're fed up with me now...!
    Thanks.
  2. Avatar
    Google AdSense Advertisement
  3. Nick185BE
    Nick185BE Member
    30
    19
    The manual should have all that info.
  4. 45bvtc
    45bvtc Well-Known Member Supporter Team Cornflower Blue Gold Supporter Team Sahara Silver SQ5 owners group Team Sepang Audi TT Audi RS3
    6,520
    13,276
    Here's mine for a 1.4 TFSi (185bhp):
    EVERY 19000 miles/2-YEARS:
    Change Engine Oil and Oil Filter
    Change Brake Fluid
    Change Dust and Pollen Filter
    Service Air Conditioning Unit
    Check Body for Corrosion etc
    Inspect from Below Engine and Gearbox and Drive Component
    Check Front and Rear Lamps
    Check Horn
    Check Windscreen Wiper and Wash System
    Check Wiper Blades
    Check Headlamp Wash
    Check Tyre Tread Depth/Wear
    Check Tyre Pressure Check and Adjust
    Check Tyre Repair Canister Date Expiry
    Check Brake Pad Thickness
    Check and Clean Plenum Chamber and Water Drain Valve
    Check Battery
    Check Brake Fluid Level
    Re-set Service Interval Display
    EVERY 38000 miles/4-YEARS:
    Change Spark Plugs every 4-years
    Check Warning and Indicator Lamps
    Check Interior and Glove Box Lighting
    Check Door and Bonnet Arresters and Lubricate
    Check Door Lock Cylinders and Lubricate
    Check Brake System for Leaks and Damage
    Check Track-rods, Track Control Links, Ball Joints, Guide Bearings, Drive-shafts
    Check CV Joint Drive-boots
    Check Under-body for Loose Fasteners and/or Wiring and/or Damage
    Check ALL Engine Compartment Items for Damage and/or Leakage
    Check Antifreeze Level and Concentration
    EVERY 6-YEARS:
    Change Air Filter
    Most of which is easy enough to do yourself... :blink:
  5. A4T
    A4T Member
    30
    Thanks. That's a huge help. The only issue is that the car tells me when it wants to be serviced and I think the intervals are 15,000km...!
  6. 45bvtc
    6,520
    13,276
    No problem, just reset the display:
