anyone got a retro fit on how to make seat belt chime when the buckle isn't fitted
vr6gordy Registered User Joined Mar 1, 2008 Messages 2,822 Reaction score 193 Points 63 Location NULL Apr 6, 2016 #1 anyone got a retro fit on how to make seat belt chime when the buckle isn't fitted
mattmanwrx Used to have a wrx. Now an S4 VCDS Map User Joined Aug 3, 2015 Messages 467 Reaction score 195 Points 43 Location Middlesex Apr 6, 2016 #2 I've seen it on vcds on my b6 s4 cab. Not enabled it, but it may just be a vcds mod?
mattmanwrx Used to have a wrx. Now an S4 VCDS Map User Joined Aug 3, 2015 Messages 467 Reaction score 195 Points 43 Location Middlesex Apr 6, 2016 #3 http://wiki.ross-tech.com/wiki/index.php/Audi_A4_(8E)_Instrument_Cluster_(8E2/8E5/8H7) Last option is seatbelt chime.
vr6gordy Registered User Joined Mar 1, 2008 Messages 2,822 Reaction score 193 Points 63 Location NULL Apr 6, 2016 #4 How dose it no the seat belt is plugged in ??
mattmanwrx Used to have a wrx. Now an S4 VCDS Map User Joined Aug 3, 2015 Messages 467 Reaction score 195 Points 43 Location Middlesex Apr 6, 2016 #5 There's probably a sensor somewhere. The pre tensioners would have to go off in a crash so I'm sure it would know. Worth a try I guess.
mattmanwrx Used to have a wrx. Now an S4 VCDS Map User Joined Aug 3, 2015 Messages 467 Reaction score 195 Points 43 Location Middlesex Apr 6, 2016 #6 Ah my bad that is for the b7 model anyways so won't work with b6
Darren92 Registered User Joined Dec 13, 2014 Messages 2,950 Solutions 1 Reaction score 900 Points 113 Apr 6, 2016 #7 sensor is in the buckle and the seat occupancy sensor is in the bottom seat cushion, should be coded enabled as standard. check coding as above.
vr6gordy Registered User Joined Mar 1, 2008 Messages 2,822 Reaction score 193 Points 63 Location NULL Apr 6, 2016 #8 Ive taken a few seats to bits now and never seen a sensor in the seat cushion
vr6gordy Registered User Joined Mar 1, 2008 Messages 2,822 Reaction score 193 Points 63 Location NULL Apr 6, 2016 #9 So what would be the last number I need in the code as it only says 0 or 3
mattmanwrx Used to have a wrx. Now an S4 VCDS Map User Joined Aug 3, 2015 Messages 467 Reaction score 195 Points 43 Location Middlesex Apr 6, 2016 #10 Yeah I guess would add a 3, see if it works. I could test tomorrow if you wanted.
vr6gordy Registered User Joined Mar 1, 2008 Messages 2,822 Reaction score 193 Points 63 Location NULL Apr 6, 2016 #11 Ok yeah thanks
mattmanwrx Used to have a wrx. Now an S4 VCDS Map User Joined Aug 3, 2015 Messages 467 Reaction score 195 Points 43 Location Middlesex Apr 7, 2016 #12 @vr6gordy I enabled the coding but didn't get the chime. So I guess there is more to it. Sorry for false hope
