  2. Dismiss Notice
Scuttle/Plenum Filling With Water Question
Chrismawa Jan 13, 2021
  1. Chrismawa
    Chrismawa Registered User
    671
    127
    43
    Im going to clean out the area under the battery as it is suffering from the common issue of filling with water. I know the small drain holes require cleaning out, but is it also advisable to remove the large rubber bungs from the holes in front of the drain holes? Any negative effects to this?
  2. Avatar
    snack-media
    Advertisement
  3. tr7
    tr7 Registered User
    415
    124
    43
    There's a bung directly underneath the battery. I just pushed the entire bung through and never had the issue again.
    I'm Just Rob. likes this.
  4. Gazwould
    Gazwould Registered User
    7,752
    3,135
    Remove .
  5. Alex Holmes
    Alex Holmes Registered User
    892
    437
    I removed the big one uder the battery but kept it safe. I also cleaned the one under the servo but left it fitted. Seema to have been okay since tho
  6. Chrismawa
    671
    127
    43
    Great cheers for that guys.
  7. Chrismawa
    671
    127
    43
    Started the job last night and finished it off this morning. Quite dirty down, there but all clean now with both bungs removed. Should hopefully resolve the issue now permanently.
    scuttleclean1.jpg scuttleclean2.jpg scuttleclean3.jpg scuttleclean4.jpg scuttleclean5.jpg scuttleclean6.jpg scuttleclean7.jpg scuttleclean8.jpg
    Gazwould likes this.
  8. Chrismawa
    671
    127
    43
    After putting the battery back in this morning I found this wire hanging loose. The other end seems to go down into the wing. Where should it be connected?
  9. tr7
    tr7 Registered User
    415
    124
    43
    Hi Chris, it's not a cable It's the battery vent tube
    Should be pushed in to the hole on the side of the batter if there is one
    Chrismawa likes this.
  10. Chrismawa
    671
    127
    43
    Thanks mate that thought had crossed my mind. Couldn't see an obvious place for it to go but I'll go have another look. Thanks for your help.
    tr7 likes this.
