oooh that is really annoying - hopefully not visible from normal standing position though? Same thing happened to the underside of teh side-skirt on my S3 parking on someones drive - had to find another place to park. After that I became paranoid about humps and ramps !!
Now I've got the S4 it looks like (but I'm not sure) that it has slightly higher ground clearance.
Yeh just real p**sed off at the moment. I would fix it but will proberly happen again. Or I might wait untill it’s warmer and put a bit of filler the use touch up paint over the top
Must have been one heck of a speed ramp.
Has your car been lowered? If it’s standard then it’s not a regulation speed ramp and I would go to the council and make a claim. Iirc it’s max peak can only be 10cm from the lowest edge. I’ve had cars dropped by 45mm+ and not had any issues with speed ramps.
