Scan tool recommendations
C4mbo
N Wales
Morning everyone
My first post on here. I was hoping for some advice on scan tools
I'm going to replace my abs pump due to a goosed pressure switch. (Cheaper to change the whole pump)
I've got a cheap bluetooth scan tool but I'm looking for an upgrade that will scan and activate the abs pump to bleed it.
Incidentally does anyone have a link to decent DIY for bleeding the abs system after replacement?
Thanks in advance.
Great forum btw
I've an A4 DTM 55 plate
I bought the OBDeleven.
Cost around £70 with the pro app.
Seems good, used it to program CC.
My sons mate bought VCDS, I don't think it was all that much more.
Do you know if you can cycle the abs pump with these?
Never done it.
VCDS you must be able to.
OBDeleven, there is a discussion thread about ABS bleeding on the OBDeleven forum. Sounds like you can.
Great. Thanks
+1 for OBDEleven. You can do everything you can do in VCDS for a fraction of the price.
You need Android though. It doesn’t work with iOS.
Thanks guys
Appreciate the help
I reccomend icarscan from launch and get the pro software which has all special functions and adaptations for all makes.
Sent from my SM-G955U using Tapatalk
I
12
12K
725
A
651
