Sat Nav A6 le mans
seasidestevo
hi all,
normally my sat nav updates with live traffic updates, shows queing traffic etc
seems to have stopped doing this over the last 2 weeks, any reason why?
tonight the m6 was a nightmare but nothing flashed up.
thats for any answers
Stevo
KrisKrk
A6 C6 4F 2010 LeMans Avant
Is it the mmi satnav you talking?
How does yours use live services and updates? Onboard sim with data plan?
What reg/motor you are?
I had mine updated to latest maps recently but with sd card.
Before that I used TomTom with live services. Now not that often or only when in the rush and need to avoid traffic.
niedzial1983
There was no live traffic on c6 apart from tmc
Sent from my SM-G950F using Tapatalk
Furryhobnob
That can't be true as my a6 Le mans satnav tells me when there's bad traffic and tried to reroute me etc?
niedzial1983
As i said tmc :)
Traffic Message Channel (TMC) is a technology for delivering traffic and travel information to motor vehicle drivers. It is digitally coded using the ALERT C protocol into RDS Type 8A groups carried via conventional FM radio broadcasts. It can also be transmitted on Digital Audio Broadcasting or satellite radio
seasidestevo
2010 a6 le mans - mmi system - presumed it was standard ?
helps me on my 35 mile commute as to coming off the junction before
like i mentioned seemed to have stopped last week or so?
KrisKrk
Is it a setting somewhere in nav to tick or something?
2010 Sline Avant LeMans and cannot see it here. Also, had my FW, SW and maps updated few months ago.
Is it in “route criteria”?
niedzial1983
You see your tmc is crossed with means no live traffic. Check what radiostations in your area have tmc.
KrisKrk
Riiight. Now I gotcha.
Is that automatic on/off depending of the area?
Hardly listen to radio. Same songs everywhere, 100 times a day.
KrisKrk
Maybe it need DAB for it?
I don’t have it
niedzial1983
I don’t have it
Press on traffic button and then in settings you can chose radiostation ...
I would show you but my satnav dvd unit broke so cant use it
niedzial1983
Also your dvd maps need to have tmc . Some dont .
KrisKrk
Traffic button?
Pictured both pages of all settings available for route criteria, after pressing right hand corner button “route” in nav screen.
Map button will obviously display a map, nav-info button display all latest vehicle gps position ect and memory button give you your latest routes and destinations.
I have 3G+ mmi, bro.
My maps are on hard drive.
Btw, which mmi you have, Steve?
niedzial1983
Traffic button?
You will still have traffic button on mmi control panel
KrisKrk
Ok. Will check 2moro. Thx
niedzial1983
Hey. The traffic button is called INFO :). I dont know why i thought its traffic. Lol
niedzial1983
KrisKrk
Yeah, got it this morning.
That’s all I got so this service is not available in my car
Steve, can you get your mmi scanned with vcds? Will it show anything?
seasidestevo
As if by magic was showing slow traffic as before ?
niedzial1983
I got my dvd sorted. Tmc works on my 2ghigh
KrisKrk
Noticed the other day, mines were on also
IMG 91651
IMG 91641
Is't it down to area where you are? Signal gets weak an mmi does not receive any sat nav info?
niedzial1983
KrisKrk
No it depends on radiostation. Some have tmc some dont .
Even though, you're not listening to the radio?
As mentioned earlier, I hardly turn the radio on. 99.99999% I go with media files (mp3/cd or dvd files playback)
If it is down to radio station and you're in wave hole (low signal zone), you're not going to get this service, will you?
niedzial1983
Yes. The system pick up a radio station that has tmc automatically . If you are in the zone where there isnt one avaiable then no traffic info
It happens in the background regardless if you listen to the station or cd...
KrisKrk
Cool. School every day.
Thank you for that
Hope this also help you @seasidestevo
niedzial1983
Thank you for that
No worries my mmi2g lets me pick with radio with tmc i can use or i can leave it and it will do it automatically
seasidestevo
mine is working as normal, i listen to the local station rock fm in lancashire so covers all my journey to work, which can be a right pain for a 28 mile journey each way.
