Saloon boot supported weight?
Liquidfusion-S3
I fall to peer pressure!
Anyone know how much weight the saloon boot liner/floor can hold?
Planning to pick up some tile adhesive which will weight approx 5 x 20kg (100kg).
Any chance it will hold?
RichardT
Don't know really, but it sounds quite heavy. I think I would make two journeys or get it delivered.
15audis3
Surely it's only the center of the floor where the spare tyre sits where it may flex, so if you spread out the load it should be fine. if it's adjustable, put it in the lowest position.
Admittedly not the same car, I've put over 100kg in the boot of my Golf before and had no problems.
Brasso
I had 13 bags x 25 kg in the back of my A6 saloon boot with no problem so I should think you will be fine if you spread it out.
RichardT
That must have been really low on the suspension!!
Snibo
It takes the weight of the Cabrio Roof / Rear Glass Window and all the electrical gubbings that go with it.
And a couple of bags of Asda Shopping at the same time.
Should be okay. Presume you're not travelling 100's of miles !!
Brasso
It was but still had a little to play with and didn't bottom out over the speed bumps on the way home.
Rob2k68
Well-Known Member
'JFTWC' ...... Job For The Wife's Car !!!!!
Brasso
Only get about 6 bags in the wife's clio. Performance is severely impaired too.
Brasso
Never had any problems. Tbh didn't give it much thought.
Tony1982
You'll be fine with 100kg, just spread the weight as evenly as possible or maybe even consider putting the seats down to extend the load space (can u do this on a saloon?) I had 4 x 25kg Olympic bar weights in my boot the other day - no problems at all, although mine is a sportback but I can't see it being too far different as far as weight tolerances go.
Liquidfusion-S3
Well I went to collect 3 boxes of 37kg tiles and stuck them all in the boot, that's about 111kg in total.... glad it didn't bend
Glad to know if I ever need to chuck a body in there lol
