It’s definitely improved since I first got it. Hopefully it will continue. And I really hope the jolt between 1st and second settles too. Although I prob shouldn’t be thrashing 1st any way
This is the kit I bought.
http://www.clutchstop.co.uk/product...agen-audi-seat-skoda-02q-6-speed-gearbox.html
The reason I bought this kit is because a lot of people who have fitted it say it as close to oem as you will get but I'm finding it the opposite
Very hard pedal.. I'll get used to that
It's the almost instant biting point and the 'on or off' clutch action that's getting me down.
I know I still have to bed it in but I can't imagine it changing too much. And I'm guessing there's no way to adjust the biting point as it's hydraulic
I emailed the company I bought it off and they say the pedal should be stiffer but the biting point should be more or less the same so I dunno
Hmm maybe my original clutch was worn hence the different feel
I had a Spec 2+ Clutch & Steel SMF, 42 DD bracket shifter bushings, 42 DD shifter bushing kit, a new OEM sliding shoe (6Q0 711 550) and Powerflex dogbone fitted last Wednesday/Thursday at Storm Developments.
I've only done 50 miles so far out of the 500 miles I was advised by both Spec and Storm to let the new clutch and flywheel bed in. So I know it's early doors but here are my current findings:
I hate having to drive it like a granny but it's obviously worth the pain, so I can't wait to actually start ragging it about in a month's time to see about high rev gear changes.
- The clutch pedal is much heavier (I knew it would be slightly heavier, but this is more than I thought it would be, nothing chronic though)
- The biting point is an inch (if that) from the floor (I expect this will get higher in time but my OEM clutch was way higher, so again not what I was expecting, however like you mine may have been excessively worn)
- Judder when reversing really slowly (expecting/hoping this will go)
- No chatter at all (I'm really surprised by this one)
- Lovely, nice & smooth gear changes from 1-6
Really hope you don't suffer from the high rpm change into 4th .I had a Spec 2+ Clutch & Steel SMF, 42 DD bracket shifter bushings, 42 DD shifter bushing kit, a new OEM sliding shoe (6Q0 711 550) and Powerflex dogbone fitted last Wednesday/Thursday at Storm Developments.
That's interesting to hear because other people say the pedal on the spec 3+ is just as light as the oem pedal to the point you wouldn't even know it's a performance clutch installed, I thought the 2+ would almost be the same
The thing is, lots of others have the same setup and don't really have the same complaints. Maybe I have a faulty part involved even though I replaced the whole lot brand new. Unfortunately it's not a case of being able to check it out very easily.Reading all this has worried me as I want to start gathering my stage 2+ parts this year.
Thought I'd do an update after 2000 miles
The clutch is solid.. there is no denying that.
Biting point never really changed. It's still very low. I've got used to it now and the pedal is still very heavy. My left thigh is like Popeyes now.
1st gear in traffic isn't very nice and is pretty tedious to be honest.
Reversing up hills etc still stinks of burning most of the time.
Fast gear changes in high revs can be very jerky due to the on/off feel of the clutch. I have replaced the dog bone mount and will look in to doing the engine mounts as they could be a contributing factor
Overall although the clutch is solid and will probably never slip when putting the power down but at a price. The overall driving experience is not very nice now. I almost wish I stayed on stock power and original clutch
Yeah it is a shame alright. Unfortunately there's a serious lack of s cars here in Ireland let alone one with the same clutch setup for me to compare. If I could try the same setup in someone else's car I'd be able to determine whether there's something wrong with mine or whether it's right and I'm just whinging
@HHS3 Im still undecided I would want as close to OEM as possible but more importantly would neee it to last so would I be looking at Sachs performance clutch with a single mass fly wheel. Would like to keep with a duel mass but if it’s still going to slip at 2+ then it’s pointless.
What would you recommend and is there much in terms of price
Well that's interesting to know. I'm (not) glad someone else is having similar issues. What are you planning to do about it?Pretty much exactly the same as mine behaves and mines the same setup. 10k miles later and it's still no better. I think it's also ruined the flywheel as that's juddering due to the harshness of the clutch. Wished I'd gone spec now
Ahhh I see. Thanks for thatSpec clutch.
Clutch: http://www.specclutches.com/692570
Steel SMF: http://www.specclutches.com/705141
I don't personally think there's anything wrong with the kit at all, it's just how other people describe the kit is incorrect. You find that on forums when people pile thousands of pounds into their modifications they don't like to talk about the negative sides so they just say it's "not that bad". They say it feels and behaves like stock because of the engaging characteristics the clutch has, it doesn't behave like a paddle clutch etc.Well that's interesting to know. I'm (not) glad someone else is having similar issues. What are you planning to do about it?
I was considering paying my Audi tech to take the whole lot apart and have a look and see if everything is healthy. However if something was wrong I would like to have a replacement part on standby to remedy it.
Out of curiosity, where did you buy your kit from?
Oh, and what do you mean by spec?
Hi Buzzman. Here a reply from Holland about the same issue. My garage installed a Sachs performance + new dual mass flyweel (brand is Luk) last week and I noticed exactly the same. When I picked up my S3 the pedal felt really heavy to press. Although I train my Calves every week in the gym, it did not feel comfortable at all. Today, 7 days later I think the pedal is going a little lighter, and perhaps I am getting used to it. Yesterday I asked my partner if she noticed a less hard pedal, but she did not noticed any change. I hope it will be (for her) better in the next couple thousand kilometers, but we will see how the clutch wil do. I will let you know in the coming weekshi. So after remapping my clutch was slipping so I upgraded to the Sachs organic clutch and also replaced the oem luk flywheel. I picked it up off my mechanic today and I have noticed the following....
1. The clutch pedal is giving my left thigh a serious workout.
2. The biting point is now about an inch from the floor.
3. The gear change from 1st to second is pretty clunky. (Could be me just not used to the new biting point)
I'm just wondering if anyone else with this setup has the same and will it get a bit softer over time.
Obviously I'm going to bed it in nice and easy for a couple of hundred miles.
