- Joined
- Dec 3, 2008
- Messages
- 10,887
- Reaction score
- 4,888
- Points
- 113
The rated torque specs on clutches are never going to be to the lbft accurate. Some hold more and how its treated in its early life plays a factor with how much it will hold. Perhaps manufacturers conservatively rate them. Id rather not take the risk. A bit of patience and mechanical sympathy and its bedded in. You could do it in a few days if you wanted to.
Absolutely.
I would think they take a minimum figure for the clutches,which most would pass,and go with that.
I'm sure also that bedding in,and relatively sensible use play a great part too,unless you're using a metallic clutch,which needs little if any of that.
I drove around pretty gently on the Sachs until I'd covered about 500 miles,and it did smell pretty hot over the first 100 miles while it settled in.
