  2. Server Issues [Search] 21-22/07/18
    We are currently rebuilding the site's search index due to an earlier database problem, so search results will be incomplete for a time. The process happens quite quickly, and we'll be keeping an eye on it. Please accept our apologies for any inconvenience in the meantime.
    Thanks for your patience.
    ASN Admin
    Dismiss Notice
S5 v8 problem p0106 then p1068
Shocker May 11, 2018
  1. Shocker
    Shocker Active Member
    104
    hi
    My s5 has been running a little rough for a few weeks
    At first I thought it was the tesco fuel but have now put a few tanks of shell v/power through it and it was still hesitating etc
    This morning when on my private runway and going for a top speed run which I can normally hit 170
    Well today at 148 I’d coughed and engine light came on
    Fault code was p0106 map sensor out of range ( garage has told me the s5 doesn’t have a map sensor and takes it from the maf and the throttle position )
    I cleared this and it never came back but car still rough
    I did notice that the little stainless levers in front of the engine seemed jammed
    I have unjammed them and they move as per they should even giving the click when they move shut as google tells me it should
    But after that I suddenly got code p1068 intake air switch over value n335 open circuit
    I have checked this valve and all seems ok even checked wiring and it goes open and close when it should
    I was going to buy a new valve but can’t seem to find out much about them
    Can anyone shed any light on these valves or is it a stealer visit
    Cheers Don
