S5 Exhaust Valve Mod
I fitted a Milltek catback non-res a good few months back (£1600 fitted) and am very impressed with it both looks wise and sound. Still uses the valves so not too far from stock sound when in normal modes but really wakes up when in dynamic sport.
Am tempted to get the Bluetooth adapter but its one more thing I shouldnt be buying!!
RhinoS5
Simon
Does that only have rear silencers and no centre box?
Mines a Daytona Grey Coupe as well!
RhinoS5
Sort of thing i'll be doing but with the stock exhaust. No centre and then keep the valved rear sections
Yep... Was going for Black but on the day i choose the colour it was sunny and there was a Black sportback in the showroom which looked ok but a Daytona grey A7 and looked great.... Had to wait 3 months then though, Black was in stock!
Thundercliffe81
Right.
Revamping this. Had an issue. I thought I would...
Got some unrelated faults that needed looking at. And I'm gonna part Ex for an RS4. So, I go to pop my plugs back in. Passenger side...plonk. Job done. Just easy as it came out. Drivers side...nada. Not playing. We tried everything. Jacked it up the lot.
So wasn't gonna take in to Audi as it's not my purchasing dealer and they're renowned for cutting your warranty for the slightest thing. These unrelated faults would become 'related' if you get me. So! Took to a trusted local garage and it's snapped. The connector that is. I'll be honest, after the man-handling through utter frustration that we gave it last week, it was a bit bent. Lesson learned for sure. Just want to move past it.
Garage are trying to source a replacement. Will this be costly and where can 'I' get one if the garage charge too much? Also...do we know where the other end of this connector goes? Is it in the boot near the space saver? Obviously I'd have disconnected that 2 years ago if I knew there was one in there.
Ugh. Don't fettle if you don't know what you're doing haha.
Cheers guys.
cuke2u
DarkyUK
Right.
Does this help? From the latest ETKA and for a 2017 S5
DarkyUK
DarkyUK
Not sure how you change those or what the damage is, if its just the outside shell you can probably do it yourself, shouldn't be a big job though.
Thundercliffe81
Nah. It's the actual male connection inside the shell that's snapped off.
DarkyUK
Ah, thats gonna be a PITA then, that part was for the connector on the cable, the connector on the motor is not listed as a part, the part number for the motor was on the screenshot though, try it on ebay or ebay.de :)
Thundercliffe81
Hmmmm.
I'll try to explain better. The female connection is on the valve control unit that sits just in front/on top of the rear muffler (drivers side). The connection and housing in that seem fine.
The lead that comes down from (I'm just guessing) under the boot behind the rear bumper and connects into the valve control unit. That's the connector that is snapped.
This is fine:
This has snapped off:
But the housing is fine. I think that might be the female end then if we're talking about the pins.
DarkyUK
Just order that original connector then, they are usually just crimped on and then the housing clips over, they come in pieces so are easier to figure out.
Any dealer or @creweaudiparts will give you a price for 4H0 973 703
Cheers, Andy
DarkyUK
Thundercliffe81
Cheers, Andy
I seen where the housing could be clipped open with a fine flathead or something. But I didn't want to ****** about any further. Found a good Audi specialist nearby that could fit the part for me.
Thanks again.
Evil Derboy
Put the snapped off piece into the connector and leave it dangling. Turn up at your local dealer with a confused expression on your face and a vague story about how the exhaust doesn’t seem to be sounding the way it previously did.
Sit back and watch as they identify a faulty connector and replace under warranty.
Job done.
Mo Akhtar
Hi guys,
Sorry to add a stupid question on here. I bought my 2008 S5 (b8) a week ago and I am struggling to find these vacuum tubes to disconnect to keep the valves open!
I have a stock exhaust and I just cant find them, does anyone have any pics to hand that would help or even just a little advice on exactly where they are. everything I find online is for the RS5 and I just can't seem to see them in the same place on my S5. I have been told at the back next to where the exhaust pipes terminate but just cannot see them, it's probably just me being blind though!
Again, apologies for the stupid question, but I do appreciate any help I may get.
Mo
DarkyUK
Hi guys,
Mo
@Mo Akhtar Have a look at the picture on page 4, they are in different places depending on the side of the car
Mo Akhtar
Thanks for the help and reply. I will take another look where that images suggests they are, I just assumed as mine woundn't have the digital/electrical connecters it wouldn't be the same as that image. I will persevere and try again!
cheers
DarkyUK
cheers
Ah, just realise you said yours was the B8 version, sorry
JimmyQuattro
Just done this mod. Bought the AWE exhaust valve simulators as I can’t be dealing with any fault codes wether they’re soft codes or not. When it goes in to the dealer there’ll be no faults shown.
Anyway, as others have said it’s well worth doing. Kinda reminds you you’re in a performance car without droning you to deaf. Not told the Mrs yet and it’s her car really so I’ll check in when she notices or doesn’t notice!
JimmyQuattro
jimmyquattro just found these online today was going to ask if anyone had tried them so well worth buying with no faults showing ?
If so will order a set
https://awe-tuning.co.uk/awe-tuning-electronic-exhaust-valve-simulators-b9-platform/
Well I bought them believing they’d do what they’re supposed to. I’ve not got any of these apps people have to check if it’s logged but the ignition was off when fitted so it shouldn’t have done.
I was a bit miffed too because while I knew what do do from reading off of here, there were no instructions in the box. Would’ve been nice to have something from AWE to say “this is how you’re supposed to do it”
And it would be better if it was double sided. By this I mean the plug should have a male and a female blank side so you don’t have to tie the cable out the way or tape over the open valve socket.
As it was I couldn’t get the tape to stick so ended up stuffing electrical tape into the socket until I was happy no **** or water could get in there.
Just my 2p. Oh and took about three weeks to come. AWE don’t stock it apparently and get each order from the US.
Craig999
Cheers jimmy will order a set like you said would be better if double sided but if it stops fault logging worth a try many thanks
Craig999
Interesting if its right no need to unplug valves just toggle between dynamic and individual (exhaust in sport ) will give it a try
Ok, so I’ve been running with the valves unplugged for a week but my ocd has been wanting to plug them back in..
Today I’ve been running live data logs from odb eleven to see what the valves get upto when plugged in.
In Eco, Comfort and Auto all in Drive or Sport they are fully variable (all open to valve 1 and or 2 closed) dependant on throttle load, closed ( lists at 90%) to open (10%) don’t know what the percentages relate to but at ignition off they read 35%.. the road speed has no relation to their status, it’s load based..
Anyway, under Dynamic and Individual (exhaust set to sport) they are also fully variable unless in Sport on gearbox, then they are always open ...
ok so some will already know that... here is the interesting bit, if you toggle to dynamic or individual after the engine has started, the valves will remain fully open all of the time until the engine is next switched off, this includes the standard drive setting on the gearbox. It reverts back after next restart, but toggling enables again.
For some this may be preferable to removing the plugs.
Adam14
If anyone is around or passing the Milton Keynes
Appreciate you made this post over a year ago, but I'm actually in Milton Keynes this week with work, so wondering if you still had the exhaust and could find somewhere to meet up in the evening to have a listen?
If you meet up have a listen from inside but also recommend standing on side of road and hear a drive by. Be warned though you will end up getting one!
Craig999
Tried this and it seems to work perfect keeping valves open continuously so no need to unplug the valves could some others try and confirm if they agree many thanks
Thundercliffe81
Haha. Nice one.
Sent from my ONEPLUS A6013 using Tapatalk
zseth
I have also noticed this, i simply start car, put in dynamic for minute or so then back to eco or individual with gearbox in ‘d’ mode, sounds same and easier gear changes as opposed to ‘s’ mode long ratios.
On switch off and restart above needs to be done again.
You will also notice sound if on idle with d mode, then flick gear lever in s mode - you can hear the deeper drone and revs rise slightly
