  2. Dismiss Notice
S5 Exhaust Valve Mod
R.A.G May 27, 2017
  1. R.A.G
    R.A.G Active Member Team Mythos Team V6 Audi S5
    149
    I've been watching the thread below with interest and decided to take the plunge and give it a go!
    http://www.audi-sport.net/xf/threads/s4-exhaust-valve-tweak.326088/
    Very simple mod, start the engine, stick it in Dynamic and Sport on the gearbox, which opens both valves, turn the car off and then disconnect the connector from each valve, taping up the male and female ends to avoid water/dirt ingress.
    The car sounds so much better, without needing to scream the knackers off it in sport mode all of the time.
    Another benefit is you don't get the one dirty exhaust, you get four mildly dirty ones instead lol!
    If you're after a slightly deeper grumblier exhaust note it's well worth the 5 minutes under the car!
    Thundercliffe81 likes this.
  2. Avatar
    snack-media
    Advertisement
  3. KBB
    KBB Active Member
    104
    30
    Still waiting for my S5, but this sounds interesting. Are these valves hard to reach? Is this mod applies to B9 S5?
  4. R.A.G
    149
    Yeah relatively easy, I didn't even need to jack the car up, just slid under.
    Yep correct, B9 S5.
  5. KBB
    KBB Active Member
    104
    30
    Cool, do you have a picture or anything? The one on the other thread doesnt rly help much.
    Also hows the sound when you cruising 70ish on the motorway? Isnt that annoying/loud a bit on longer journeys?
  6. R.A.G
    149
    It's a very awkward area to get a clear shot of but once you're under there it's very self explanatory.
    It's pretty subdued unless the engine is under load, certainly no obvious drone.
  7. Keef
    Keef Well-Known Member Team Daytona Audi S4
    1,517
    1,183
    If you look at the link above to @Thundercliffe81 post that has a picture of the connector.
  8. AJ Jacob
    AJ Jacob AJ
    261
    198
    43
    This can be easily achieved via VCD....which I find a easier solution, speak with @DJAlix for any VCD stuff.
  9. R.A.G
    149
    I wouldn't describe it as "easily acheived" unless you know the coding and fancy sharing?
    Look forward to some insight on this as I'm not aware anyone has cracked the coding for this on the B9 S4/5 yet?
  10. Ridders71
    Ridders71 Member
    81
    43
    I thought you could just use "individual " mode on drive select to set exhaust to loud and leave transmission etc in normal?
  11. R.A.G
    149
    Unfortunately not, in Dynamic (or individual with Dynamic set for exhaust) it still opens and closes the valves throughout the rev range and at cold start, hence the single sooty tail pipe. In Dynamic and Sport auto the valves are open all of the time, you just wouldn't want to drive everywhere in sport auto.
  12. Avatar
    snack-media
    Advertisement
  13. Ridders71
    Ridders71 Member
    81
    43
    Ah, thanks for clarifying that. I had assumed that sports was only a gear box setting. Seems a clumsy implementation. I guess that's why the individual setting referees to engine noise rather than exhaust noise?
  14. R.A.G
    149
    It doesn't make a lot of sense does it, you'd think they'd let you set it open through drive select like you mention.... Probably EU noise regs :sob:
  15. KBB
    KBB Active Member
    104
    30
    I've decided to do this after I've finally found the jack for the car. After jacked it up it was much easier, but still needed to use a little mirror to see the top side of the plug: there is a little pin there that needs lifting(or pulling, depends on from where you look at it) after which the plug just comes out easily. The passenger side was a 1 minute job, the driver side was more difficult for me too, since the awkward position that is in.
    Result? Amazing, sounds much nicer now, don't need to rev it to get that deep sound out of it. Thanks for sharing this! :)
    Have you guys already seen what error messages this throws?
    I was in the Audi dealership today to pick up a boot liner and those Audi rings exit lights and asked the guy there what he thinks about this mod. Of course he didn't know jack about it, so he asked the technician who said this wont work since the valve shuts off if there is exhaust coming out and the switch keeps it open apparently. But they also told me that it doesn't matter what I do with the exhaust, I can even replace it, wont effect the guarantee. So I'm not sure if I'll plug these back on when taking it to service.
  16. R.A.G
    149
    Glad to hear we've got another valve modder lol!
    There's an error logged for each valve, something along the lines of exhaust left bank pressure error, and the same for the right bank.
    Takes seconds to clear with OBDeleven.
    I'm sure someone will work out how to code them open eventually so we can leave them plugged in with the same effect, think the B9 platform is a bit new still, look forward to someone working it out!
  17. KBB
    KBB Active Member
    104
    30
    Yeah, that would be awesome! Like programming the valve to open/close on the press of the "joker" button on the steering wheel, since the available options are unless anyway.
    I have ODBeleven, so I can clear them codes, but whats the point when I'm taking it to service while its still unplugged?
    To be honest there is not much a point to have that thing(ODBeleven), I couldnt find any useful app to use, and all the details it showed me either available on the dash or pointless information. Is there a forum for this, or can you tell me what do you guys use that for?
  18. R.A.G
    149
    The idea of clearing the codes is in conjunction with plugging the valves back in, on the off chance having them unplugged caused any awkward conversations with Audi/dealer due to warranty claims etc (very unlikely though).
    The most useful things I've used OBDeleven for is Scandinavian DRL (rear LED's on during the day along with fronts), bleep when locking, and extending the boot release time out from the key fob (kept opening the boot from my pocket by accident!)
    There isn't specific forums for it as such but lots of individual threads across many different forums with useful info, the coding is the same as the B9 A4 and a lot of similarities with the latest Q7 so a bit of searching will dig up various content/instructions.
  19. KBB
    KBB Active Member
    104
    30
    I see, I'll take a look then, thanks!
  20. KBB
    KBB Active Member
    104
    30
    I've just finished messing around with OBD11. Managed to get the Scandinavian DRLs on, useful feature! But the rest you mentioned I could not find. Bleeping on lock would be amazing! What car do you have?
  21. R.A.G
    149
  22. KBB
    KBB Active Member
    104
    30
    Strange, I have the same thing, but cant find the bleep when locking in the apps. Is it somewhere else?
    Thanks for the link, I'll have a look later.
  23. R.A.G
    149
    Yeah they don't do an app for that so you have to follow the coding and adaptations.
    It can be a bit daunting the first time you do some coding but take your time and follow the instructions and it's pretty simple stuff.
    Worth noting you need OBDeleven Pro to access the coding UI.
  24. KBB
    KBB Active Member
    104
    30
    Yep, I've realised that now. I can see where the adaptations is done for the lock chirp, but I cant do the coding. I go into long coding section on "Central convenience(46)" and it throws out a bunch of things not even related to the matter and basically I don't have clue what am I doing. Is there a tutorial for this somewhere?
    I've got the pro btw.
  25. R.A.G
    149
    You basically need to code the functionality so it's a visible option to enable in the MMI central locking settings and then set how it functions in the adaptation menu.
    If you spend some time reading that thread in the link above it will slowly start falling into place, I'm not aware of a tutorial but there might be some YouTube vids knocking about.
  26. KBB
    KBB Active Member
    104
    30
    Okey, I've finally found it! There is a little 0/1 icon at the top of the screen at "Long Coding" where it shows the bytes and bits. Thats the thing I couldn't find before.
    So successfully coded the car, got the option now in the menu for the central locking beep! Changed a couple of things in adaptation, 2 beeps when locking, 1 when opening, 5ms beep time. So it works when locking, but doesnt beep when unlocking. Did you changed anything else on yours to do that?
    R.A.G likes this.
  27. R.A.G
    149
    Nice one, I set the sounder settings for beep time from 10ms to 60ms (the max). It turns it from an almost click like noise to a full on BEEP!
  28. thefunkygibbon
    thefunkygibbon Member
    107
    25
    Unclipping is simple when you understand how the clips work. Push the grey bits out and push down/pinch the now slightly extended bit. Pull.
    Just not 100% sure at what point all valves are actually open!
  29. R.A.G
    149
    As I understand it they are always open when the engine is off, which would make sense to reduce condensation in the system, but I put mine in Dynamic and Sport before I turned it off and then listened for any valve movement to be sure.
    You'll know if you unplugged them while a valve is closed when you restart the car by holding your hand over all four pipes to feel for exhaust pressure.
  30. gldy_b
    gldy_b Member Team Mythos TFSI Owners Group Team V6 Audi S5 quattro Audi A5
    57
    12
    Been following this thread for a while. I've collected my S5 and intrested in doing this mod. I can only see the valve opening and closing on one side. The other side I can't see the valve?
  31. KBB
    KBB Active Member
    104
    30
    On the driver's side it is quite easy to see, since it is very close to the end of the tailpipe. On the passenger side its a bit further in tho. If you go under the car you'll see where is the valve located and why you cant physically see it if you just look into the pipe.
    I dont see why would you need to see it tho, just do the mod it has been described, you'll hear the difference :)
  32. KBB
    KBB Active Member
    104
    30
    I've just wanted to give a little update and bump to this thread with a video.
    So there are loads of videos on the the internet about the sound of the S5 but they hammer it like hell. The whole point of this mod, that you can enjoy the soundtrack with normal day-to-day driving. In this footage I've never went over 2500 rpm, most shifts were around 2000. Gearbox was in Auto and normal D mode.
    Pair of headphones and hd mode recommended.
  33. Avatar
    snack-media
    Advertisement
  34. Liddo
    Liddo S5 Sportback Lease
    111
    49
    Lovely and burbley, i really like that! Thanks very much for the post up ;)
  35. SRB93
    SRB93 S5 B9 Coupe - Glacier White Team Glacier Team V6 Audi S5 Coupe
    427
    142
    43
    Sounds great! Just the perfect amount of sound without being annoying.
  36. S32B
    S32B Well-Known Member S tronic Audi A5 Coupe
    5,986
    6,971
    How much is the official Audi one mate? I have a invite for 20% off.
  37. KBB
    KBB Active Member
    104
    30
    £95
  38. Liddo
    111
    49
    £95 for a boot mat :fearscream: will be scanning Ebay for mine :tonguewink:
  39. ChrisH370
    ChrisH370 Member
    298
    15
    I've got the exhaust valve done. Makes the car sound so much more sporty and fun to drive, even in Efficiency mode.
    It brings the exhaust system alive.
  40. SRB93
    427
    142
    43
    Did you just disconnect the cables and remove error codes using OBD?
  41. ChrisH370
    ChrisH370 Member
    298
    15
    Yes, apparently its only the near side valve that needs disconnecting. There's no point in removing the error code, it can't be cleared whilst the exhaust valve is disconnected. My local dealer did it.
  42. SRB93
    427
    142
    43
    Hold on, you only disconnected the one valve? I was under the assumption that you must disconnect on both sides.
  43. chanlon1
    chanlon1 Active Member Team Ibis Team V6 Audi S5 quattro
    185
    27
    Did your dealer disconnect the cable bit or did they clear the error code?
