S4 exhaust on 1.8t?
ian52
2000 a4 1.8tqs-yellow
Anybody done this on a 1.8t quattro? I mean i know the front will be different but im sure from the mid section will fit if you got a custom front pipe made. All this is assuming that the s4 has a bigger dia exhaust and im sure it would do. Could make a cheap upgrade thats still nice and quiet.
Broken Byzan
Photographic Moderator
Staff member
Moderator
Already doing it, picked up an S4 exhaust for £40(If it ever arrives) its 65mm twin in iirc, so i am gonna chop it shy of the y split and stick my CAT in there and run a 3 inch DP from turbo back
ian52
Great minds think alike. For how cheap you can get one its got to be worth a shot. It should just fit on the original hanging points too i would think.
Broken Byzan
Staff member
Moderator
it looks like it will from the pics i was able to get from Elsawin etc.
The main difference i can see is the bore is larger, and it splits into 2 sections at the front to mate to each bank seperatly. Fortunalty it comes out of the box in one pipe then splits into 2, so i aim to chop it at the Y
hardhitter
Sounds like a good idea. I think a Milltek S4 single 3" system with the Y piece removed and new downpipe in 3" would make a good system.
ian52
Thats the idea i had. Chop it at that point and just get a custom front part made. That should do the job fine for a turbo same as yours. Should be about standard s4 power then anyway.
Broken Byzan
Staff member
Moderator
I hope so Ian. I have started making the DP (Pics in my hybrid thread) If a std S4 exhaust can make 320 on a chipped S4, we should have no problems.
If i were able to afford it, I may have got one of those £200 S4 stainless Ebay jobbies and modded that first, but I have no way to weld that, so oem it is.
FWIW S4marsh has an exhaust for sale
jcb
milltek is a 70mm or 2.75" system.
I picked up mine second hand but am about to replace CAT and Dp with a 3" one.
hardhitter
Yeah, the Milltek A4 1.8 TQS system is 2.75" but the downpipe is only 2.5" for some reason. I was thinking of getting a 3" cat and downpipe going into the Milltek system.
jcb
The Milltek downpipe is 67mm as opposed to 70mm. negligible I would have thought. just had to replace the clamps on mine (stupid fecking things are not stainless and rust away like chocolate!)
Its a packaging issue as far as I can see, the smaller pipe fits into the larger one as you move backwarda along the system. I guess it saved them having to taper one or go with vbands.
where can you get an S4 exhaist for £50?
aragorn
"Stick a V8 in it!"
Staff member
Moderator
Why not just use the OE sleeve clamps? That way you dont lose any diameter at all, and when you come to remove it, it actaully comes apart easily!
voteforpedro
Very interested in this idea. Pics/info wanted please. :)
Broken Byzan
Staff member
Moderator
where can you get an S4 exhaust for £50?
I scored mine from SRS, i am sure plenty of guys will be willing to make a few quid when they upgrade to stainless.
( In fact mine was £40, but i was also offered one for £60, so i averaged LOL)
Blue_Thunder
I binned my S4 exhaust when I upgraded to Milltek. Wish I hadn't now. D'oh!
