S4 alloys on a 1.8tqs? What size needed?
JAM35F
Will a set of oem S4 Alloys (6 spoke) fit straight on to a 2000 1.8t quattro sport saloon?
They are:
17x7.5
45 offset
5 stud
225/45/17 tyres
Part number: 8D0 601 025 N
No idea what the pcd is though.
Will these fit? Will all 17 inch S4 avus alloys fit, from both b5 and b6?
Will my original bolts be ok or do I need longer or shorter ones?
Lastly, anyone have any for sale!!
cheers in advance
jcb
offset is a little high (makes wheel sit IN the arch) but they bolt straight on.
you should be looking at around ET35
no need for change of bolts though
I have 8.5x18 ET35 wheels on, no problem, plenty of space
JAM35F
thanks for quick reply. Are original s4 alloys available in 35 offset?
Fraser
they should be fine straight on, i have them on my t sport
et45 originals bought from BlueThunder
JAM35F
So a 45 offset on S4 alloys is the norm? And will be ok on a quattro sport?
Is 35 offset just a personal preference for some when buying new alloys and they have the choice?
Siena
ET45 is standard S4 offset, and will be fine on your QS.
Most aftermarket will be ordered as ET35 - 38. It's popular, because it fills out the arches more, but with certain geometry settings, and dependent on ride height, they're more likely to tramline.
jcb
my OEM 10 spoke i.8tqs original wheels were ET35
Siena
Very true.
The 1,8TQS is a less powerful car than the S4, lighter too.
Torque tends to pull the wheels in under full power - toes the wheels in.
It makes wheels with lower ET numbers less suitable for big torque, as the car may tramline.
We know these things, but we tend to modify our cars to suit our personal taste.
You sure? Mine are not.
I have 20mm spacers on the rear of my car to space them out.
Unless some 1.8T quattro's got different Boleros.
JAM35F
I have the standard ten spokes on at the moment (usual ones with the peeling polished lip).
All the replies are appreciated though I have to admit most of it is going over my head.
Summary would be that et45 is standard on S4 alloys and they will fit straight on to a 1.8tQS with no problems?
jcb
Very true.
B5 RS4 runs ET20 as standard.......
sorry, just being an ****, not meaning to contradict everything you say : )
that said I have just had my arches pulled and am planning on running ET20 RS4 wheels with 10mm spacers to clear my brakes and give me a bit of a wider track. sure it will probably tramline a bit, but as I rarely drive in a straight line I hope I won't notice!
jcb
no you are right actually, just got me thinking and I checked
ET43
Siena
True, but suspension geometry's so different to compensate.
