rickparmar said:for some reason i always thought the TT brakes were the same as the S3
Silversea said:996 GT3.
Outstanding brakes at any speed and much better pedal feel.
Silversea said:Approx 5mm more travel than with the original set-up, but without any doubt a much improved pedal feel.
If you were to measure the fluid displacement of the large single piston, I don't think it would be too much less than the 4 smaller pistons.
Ess_Three said:use 996 C2 rear callipers
Aky said:Not sure whether its me being thick but why use the rear ones rather than fronts? Could the fronts be used?
Silversea said:Can't speak for the S3, but I'd guess the M / Cylinder is the same size as my 225 TT, I always found the original brakes to be less than ample for the car, not talking about track days etc but general day to day driving with a few blasts on favourite B roads etc.... Fitted the Mov'it kit (GT3 Mk1 4 pots with the usual 322x32 discs) opted for the BE-M46-Sport pads, I can honestly say that there was a huge improvement over the standard brake set up (brakes were like new with O/E pads), as I mentioned, the pedal has about 5mm or so more travel but the feel of the brakes are much improved. Added the 308mm ECS kit later on to the rear, which again made a bit of an improvement over the standard.
Ess_Three said:But they don't say Porsche on them...
But they do save you £500.
marmite said:Silversea Loving the wheels on your car..have you eaten through those MIch sports yet? notice you got Rosso's on
