  2. Dismiss Notice
S3 Stage 2 Plus General Opinions
S3Jay Nov 3, 2019
  1. S3Jay
    S3Jay Registered User
    I have been looking into potentially going stage 2 plus with my S3 and was wondering if there is anyone on here that are at stage 2 plus and could maybe provide some insight into what it has been like since the stage 2 plus in terms of driveability, Also reliability. Any known issues? Things to look out for? I look forward to everyones response.
  2. Avatar
    snack-media
    Advertisement
  3. samuelh_888
    samuelh_888 Registered User
    2,081
    858
  4. mechanic69
    mechanic69 Registered User Gold Supporter VCDS Map User
    2,066
    784
    365 to 380bhp, 100 over stock, with the right hardware and map (Rtech) you won’t regret it amazing grunt and good for daily driver
  5. prt57
    prt57 Registered User
    1,799
    621
    Stage 1 is the best value as the software works with standard hardware. 1+ costs a bit more as you will need updated internals in the hpfp. Again you can get away without any extra hardware apart from the tweaks to the hpfp.
    Stage 2+ needs quite a bit of extra hardware and so the price rises quite a bit.
    At stage 2+, the car does not feel much different until you get to 4K revs. Then it becomes a beast all the way round to the redline which probably have been raised to 7,200 rpm.
    I have APR software but I may change to a custom map next year to get the most out of the extensive hardware I have installed.
  6. smurfworth
    smurfworth Registered User
    2,031
    570
    Awesome for a daily driver, not a lot can match it on the roads. Only thing that doesn’t like it mechanically is the clutch/flyweel. Even the aftermarket Sachs organic isn’t really upto it mines been in for maybe 15k miles now and the dual mass is knackered already and the bite is in the middle of the pedal already.
    just don’t launch it off the line and it’ll last, if you do driveshafts etc won’t take the abuse very well
  7. paddy
    paddy Registered User
    6,818
    907
    APR 2+ here. Runs like a dream, bought new, first 50k on Revo stg 1, 40k now on APR so 90k in all and great. DSG will take it no problem but i wouldn't even think about launching it.
    I keep looking at F-Types though.....:)
  8. Sayam
    Sayam Well-Known Member VCDS Map User
    2,801
    664
    Have driven a mk6 Golf R that is MRC stage 2+ and wow! Assuming the results are similar on the S3 then definitely go for it.
    Not sure about clutch/flywheel in manual cars though, the car I drove was DSG.
  9. S3Jay
    Awesome. Thanks guys. Abit apprehensive about the clutch seeing as i'll have to upgrade it. Hopefully it's not too uncomfortable to drive with an uprated clutch. Time to save up!
  10. prt57
    1,799
    621
    The latest clutch for the TFSI engine is made by RTS. Pedal pressure is the same as normal. I am running one in at the moment on my car. A bit of judder in 1st and reverse at the moment that goes over time. It just needs a few revs more than normal when setting off but that is improving.
  11. Moxy89
    Moxy89 Registered User
    376
    161
    43
    Why wouldn't you launch it, day will take it no sweat
  12. Avatar
    snack-media
    Advertisement
  13. paddy
    6,818
    907
    Yea , tell that to the first Dif and haldex that failed at 50k miles and set me back £5k.
  14. Moxy89
    376
    161
    43
    I’ve only launched mine 3 times. My
    Hadlex pump has just died however not the same issue. Think it’s just hit and miss with launching some cars get launched daily and are fine some just don’t like it
  15. paddy
    6,818
    907
    I probably didn't launch mine more than 3 times and the Diff started whining , killed a bearing and you cant get the unit apart to replace them.
