S3 Intermittent Performance
eatdirt13 Aug 12, 2018
  1. eatdirt13
    eatdirt13 New Member
    Hi Everyone,
    I have recently picked up quite a good condition S3, which was pretty difficult to find!
    It is a 2002 with the BAM, with 113,000 miles on it.
    It is completely standard apart from the Airtec Intercooler, and Badger5 TIP which I have just installed.
    Basically, the car always has a rough idle from cold until the revs settle. When driving, say you come off a roundabout in 3rd, foot flat, the turbo spools as it should at around 2.5k, then when it hits peak, it drops off, then comes back in even stronger at about 4.5 - 5k. I'm sure it could be a whole host of different things, but maybe someone has had / or knows of a similar situation and what solved it.
    I've had numerous cars in the past and I'd say the car feels like it has about 190hp, not 225! BUt as I said when the turbo kicks in for the second time higher up the revs, it feels as fast as I think it should, but it doesn't give me it from the start...
    Thanks in advance.
    Matt
  2. Avatar
    Google AdSense Advertisement
  3. Tj 0785
    Tj 0785 Well-Known Member Silver Supporter VCDS Map User Bronze Supporter Audi S3
    2,684
    715
    The 4wd makes the s3 heavy they are not really that fast as standard and a lighter less powered will feel quicker, even with no faults
    One of the best things to invest in isa vcds cable scanning the car when you have a issue should be the 1st port of call, have you checked all hoses are tight ? Could be an air leak
  4. eatdirt13
    Sorry I did forget to mention it has been scanned and it's showing zero fault codes! However there is definitely something a miss with there being a massive flat spot between 3-4.5k! I'll probably get a boost leak check done and go from there. Cheers
  5. Tj 0785
    2,684
    715
    Did you have the problems before you fitted the tip and fmic?
  6. eatdirt13
    Yes I did, my hope was fitting those may help but no. I'm not that bothered as I have plans for a 400hp build soon, but until then it would be nice to know it is running right!
  7. Tj 0785
    2,684
    715
    What you planning to get 400bhp ?
  8. eatdirt13
    Head refresh, supertech valves, JE pistons, IE Rods, 2.0 TFSI crank, injectors, K04 hybrid / manifold, Ext wastegate, and any other ancillaries as needed! That should just about do it I think
  9. Tj 0785
    2,684
    715
    400 on a hybrid will be pushing it most seem to be high 300
    I’ve only seen 1 400bhp ko4 hybrid and that’s badger5’s lupo
    hydro s3 likes this.
  10. eatdirt13
    Yeah I have heard this, may even look into a GT25 550
  11. Tj 0785
    2,684
    715
    You probably need a gt28 or gt30 got that
  12. Avatar
  13. S3AMJ
    S3AMJ OEM+ Team Brilliant Black Audi S3
    1,233
    340
    I Agree with TJ, if your 400bhp is a approximation then Hybrid will net you just below that. I’m going the hybrid route and a few other have already or in the process of doing it. But if your determined for 400bhp then you’ll need a bigger turbo and even bigger pockets.
    Tj 0785 likes this.
  14. Tj 0785
    2,684
    715
    If just stick to your hybrid turbo for the sake of 20/30 Bhp is not worth the extra thousands you need to spend anything over 350 will still be quick
  15. Stuart B
    Stuart B Well-Known Member
    3,448
    739
    If you are having a total engine rebuild why are you worried about some leaks, dodgy sensor or whatever now?
    What did you scan your car with to get zero faults? I have never got zero faults in 3 years of ownership on two separate cars using vcds
  16. eatdirt13
    Well that won't be until early next year probably, so I would like it to be running fine until then.
    It was VCDS, there were a couple of codes for radio and alarm, but nothing to do with engine etc suprisingly!
  17. Rainbird
    Rainbird Well-Known Member
    443
    265
    Unsurprising :whistle2:
  18. Stuart B
    3,448
    739
    Lol stop making one statement out of two unrelated paragraphs.
    You are #fakenews :D
