- Joined
- Apr 22, 2015
- Messages
- 721
- Reaction score
- 76
- Points
- 28
Late 2002 S3 Idle and Persistence of vacuum
Ive 'odd' idle problem , which Ive been chasing down for a while , everything is nearly 'ok' the idle speed is constant , but with a sight hunting and a hint of erratic firing ... turn the air-con 'on' and its very much worse quite lumpy . No error codes, throttle valve has been off and cleaned , new plugs , filters , oil etc .. runs fine at speed etc.
How long should the brakes hold on for , when the engine is stopped ? I loose servo in about 15 seconds Brakes work fine with engine running , sometimes give the impression of a slight delay ..
There is no vacuum reservoir in the system ?
From the various posts , this points to some form of leak on the servo hose ? any thoughts ? what is likely to need replacing ?
The hose assy etc part number's ?
Tnx-Graham
Tnx-Graham
